Advice on older bookshelf speakers to replace Tannoys
JRH64
Hi
My setup is: Nad 3130 amp
Arcam cd73 cd player
Tannoy mercury m2 speakers
Arcam ir dock for playing lossless and 320 mp3 via ipod classic
I have had the Tannoys from new and really like them but im getting back into my music after a while off. Im thinking of upgrading the tannoys for something a little better.
I do like the older british hifi. I know its a budget system but can anyone recommend a significant better bookshelf speaker over the tannoys. Ive spent ages looking at speakers from the same era
but im still at a loss. Or do i need to consider something modern?
Any advice is much appreciated
Hello and welcome to ASR.:)
Your budget?
Or do I need to consider something modern?
I think you should. New or not so many years old used. With old (decades old) you don't know for example if the ferrofluid in the tweeters has dried out, if the foam edges in the woofer are rotting away (only buy old speakers with foam edges if you are willing to do a refoam)
There are good new two-way speakers that, in my opinion, have a reasonable price and are better than Tannoy mercury m2.:)
Nothing else you're thinking about? For example; streaming music? Add a subwoofer together with some bookshelf speakers?
But if you're interested in bestsellers and/or classics. In the thread below mostly UK speakers. Based on What Hifi's list, so a lot of UK bias. Tannoy mercury m2 is on that list:
Hi
Thanks for the eply. What more recent make/model of bookshelf speaker would you recommend. I understand buying vintage is a risk.
I have been looking at some ruark models and the epos m5. So many options, bit of a headache.
Hi
It depends on your budget. Plus where you live, if they are available.
An example is these, price around $1000 per pair:
They are good bookshelf speakers. :)
Also these. Note a decent power/ currenstrong amp is recommended with them:
A little cheaper, but good these:
Tip:
Edit:
Disadvantage of modern speakers, they usually have lower sensitivity than vintage ditto. You only have a 30 watt amp. If you like to play at a fairly high volume and were to get one of the speakers mentioned above, get an amp with more power. At least I would have done that if I were you. As Erin, who did the test on the good AsciLab C6B, said in connection with the test of that speaker:
Use a strong 4-ohm-capable amp with at least 100W/channel
(also to manage that they dip low in Ohm, check the impedance curve)
Then you have the option of active speakers. I missed that you have two sources. With active speakers, you can use your Nad 3130 as a pre amp.
Or this pre amp could be an alternative:
I doubt there is any audible difference between Fosi Audio P4 and Nad 3130 (if it operates according to spec) in pre amp mode. But Fosi Audio P4 is small and takes up a little space plus it has a volume remote control which is handy when you play your CDs. :)
Amir:
Finally and very surprisingly so, the volume control is motorized and activated through remote control (not shown)!!!
Also your Nad 3130 is around forty years old. Old electronics don't last forever. Sooner or later....
Maybe a more powerfull and newer amp plus something like the elacs is the way to go.
Thanks again
i'd go with true mini's from philharmonic audio or if you're gonna get a little liberal with spending i'd go ascend sierra1 v2's or the ceramic mini from philharmonic audio.. these aren't "old" speakers but the true mini's aren't expensive at all ...
Thanks again
Maybe so. It mainly depends on how loud you play and how dynamic the music you listen to. It's possible that your NAD 3130 will handle it just fine. You'll have to try. You can always buy a new amp at a later stage.:)
Elac Debut Reference DBR-62 is definitely one of the favorites in the price range they are in.
I dont really play that loud due to neighbours, if there out i do crank it up a bit.
I will take onboard all the above advice.
Really appreciated
You may need to be prepared for a "tonal" change if you buy modern gear. Your generation of loudspeaker was designed before somr of the modern research and tools were available. Many of the speakers people here will recommend tend to have a flatish on-axis anechoic response and smooth off-axis behaviour. They are closer to neutral than many 80s and 90s British designs.
I suggest you treat the room and enjoy that first. I'll bet that alone per dollar spent will give you a lot better results. I have no idea how you are set up, but then it wasn't mentioned at all. Add a good sub/bass system and room treatment, and you will think you purchased a lot bigger, better system. You may need to add parts like the sub/bass, but those changes, like the room and a good LF system, transfer right into a higher SPL main later on. Personally, I find most speaker quit good once you understand what makes them and all speakers' systems sound better. Room and a LF upgrade are always the better move up vs sideways.
Regards
You have a point but the Tannoy M2 that TS has is in line with what you said about flatish on-axis if you can believe this. Test Tannoy M2:
The resulting averaged room-response curve was a very good ±2.5 dB from 45 Hz to 10 kHz, falling off above 10 kHz to about -8 dB at 20 kHz. We measured the horizontal directivity 1 foot from the tweeter, at angles of 45 degrees to either side, and averaged the two measurements. The off-axis curves were generally quite similar to the high-frequency rolloff of the room-response measurement.
Quasi-anechoic MLS frequency-response measurements at distances of 1, 2, and 3 meters confirmed the excellent dispersion and range of the speaker’s frequency response. Except for some irregularity at 9 kHz, which appears in all speakers we measure in this way and is obviously a measurement artifact, the speaker’s response was within +3 dB over the full measurement range of 300 Hz to 20 kHz.
I have a pair of Tannoy M2 that I plug in sometimes. Quite ok but somehow boring. I want flatish on-axis and ..so I don't know what it is that I find boring, or mediocre is a better word, with them.
Maybe it's that they fall off so much after 10 kHz, maybe it's that the ferrofluid in mine has started to dry out that makes the tweeter boring. I don't know. They measure with Wiim and UMIK-1 in my room well, fairly flat without any major deviations.
In any case IF TS gets new bookshelf speakers, he should think about the differences in bass capacity between small speakers. For example, I consider the
Wharfedale Diamond 220 to be a better speaker, except for the bass where the Tannoy M2 is better. More, better punch. None of them are bass monsters but if you compare them to each other.
Subwoofer as @OldHvyMec is talking about in the post abow might be something to consider.
Wharfedale Diamond 220 plus sub, well integrated with each other, gives (I can promise) a really good sensible super budget solution.:)
Speaking of bass. ADAM Audio's active studio monitors usually have good bass for their size. For example these:
Since they are active, use the NAD 3130 as just a pre amp with them, alternatively sell it and buy, for example, the Fosi Audio P4 pre amp that I recommended in #8 above.
Hi
Vintage British are still some of the best sounding speakers and they don’t cost a small fortune.
Is there something not to your liking or problems
with the Mercury.? I’ve seen enough seller remorse people love their speakers and looking for something more. and regret selling their previous speakers.
I no longer have my Role Audio Kayak. 4 pairs of speakers later wish I had them back.
Maybe another way forward could be to keep the Tannoy M2 speakers. Sell the NAD 3130 and the Arcam ir dock. Get a Douk A5 amp plus WiiM Mini streamer (you can switch between Wifi streamed music and CD via the aux input on the Wiim).
Advantage with the WiiM is RoomFit. That allows you to get a pretty good FR in your listening room. Douk Audio A5 has sub out with HP filter so it makes it easier to integrate with a subwoofer (which is then purchased). It can probably really liven up, and improve TS sound. Preferably together with physical acoustic fixing measures in the listening room if necessary.
Tips on subwoofers. I don't know how many of the ones Erin tested are still on the market:
Edit:
The WiiM Mini's built-in DAC is not state of the art. However, it is possible to bypass that DAC by using the mini's digital output to a good external DAC (which I do). Or you can buy the WiiM Pro Plus which has a good built-in DAC.
(Audible differences WiiM Mini built-in DAC vs a good, state of the art external DAC, WiiM Pro Plus built-in DAC? Most likely not. It's still the speakers that cause the most trouble or distortion)
Hi
I find this a very difficult request because we do not know what part of the world you are in (at least I don't).
Recommendations will not help if they are unavailable to you.
I do not think that you would need to give out what city or you are in but a country or region would be helpful.
