Hi guys, I've been lurking for some time and now need some advice on what to buy.
I currently have a o2/odac from headnhifi with a sennheiser hd800 (single ended cable), I also have a densen b-200/b-300 pre/amp with audiovector m3 speakers.
If possible I want to replace the o2/odac and the densen stack (which is almost 20 years now) with something newer with digital inputs.
What I'm looking for is either an all in one or seperate devices that can drive both the hd800 and the m3 speakers (they are about 90/91 sensitivity I think) with optical input so I can connect my tv/tuner, usb input from my pc and a remote. Stuff like coax, bluetooth (one or two way), display, wifi/lan etc. would be nice but are not essential.
I haven't decided on a budget but max 800$ ish, I live in Norway so there will be import tax on stuff outside of my country (25% I think).
Either new or used is fine as long as it is isn't obsolete.
I have been googling and looked at measurements but can't decide on anything, it doesn't have to be the best measuring dac/amp but "good enough", I'm sure my almost 40 years old ears are not in their prime
The small design of topping dx3pro is nice but unsure which amp I would use with it, I looked at nad d3045 which had lots of cool stuff but seemed weak for both speakers and headphones.
