Advice On New Film/Gaming Headphones, Wired, Closed Ear
yellow_run_2345
Hello, I'm in need of advice on which pair of closed ear, wired headphones to buy:
1. What is your budget?
~USD$200-350 [£150-260]
2. What are you looking for?
Closed ear, wired, budget PS5/TV listening [via PC] Headphones
3. How will you typically be using the gear?
Sat at a desk [PC] and in a chair [PS5]
5. What do you intend on using for a source?
PC soundcard output and using a PS5 controller over bluetooth or the TV audio jack if the cable's
sufficiently long.
6. What material will you be using your gear for?
Gaming PS5/TV listening
7. Are you willing to buy used?
No, unless completely refurbished with all skin contact surfaced replaced.
The previous Sennheiser Game Zeros [before they were bought over/partnered with EPOS] lasted me 5+ years with a lot of patch ups, glue,
3+ sets of earpads, and 10+ knock off cables. I'm considering buying the same headset but I've seen comments that the quality and
customer support has drastically been lowered, and I can't find a new pair at that.
A wired Sennheiser would be my preferred choice/style.
Three headsets I’ve bought in the past month:
1] Sennheiser HD 599 SE Open-Back Wired Audiophile Headphones via amazon [using as my current pair, though the bass is too overpowering]
2] Sennheiser PC350s via ebay [keeping to try and patch up the Game Zeros]
3] EPOS H6PROs via amazon [returning, bad construction and weak sound]
In an attempt to understand and compare the above I've been using this website:
though by all metrics the Sennheiser HD 599 SE [apparently effectively the same as the HD 599 standard version] should best the Game Zeros, and in reality they don't.
The above all sound nothing similar to the Sennheiser Game Zeros; the audio’s missing something. Firing a gun in Cyberpunk 2077 etc
Found some review site confirming it's the treble. I'll look for an external device to boost it then I guess.
It’s as though these backup headphones only register the bass or something. It could be that I need more treble, so perhaps there’s some sort of external device or power booster that I can buy. As you can tell I'm uninformed, misinformed on audio, and frustrated. Please help me if you can.
My apologies for the wall of text and probable lack of clarity.
Thank you for any help, and for your time.
Welcome to ASR!
If the budget allows - Sennheiser HD 480 PRO
I’m not sure sites like Versus are very useful for comparing headphones, since they mostly compare specifications. It’s better to look at things like frequency response and distortion measurements to get an idea of how a headphone might compare to others.
Also, if you want to get the most out of your headphones, it’s worth doing some research into EQ. ASR has plenty of threads on the topic.
