The A11 Tribute is another small amplifier with big aspirations stated in the literature. As a example we have a peep here that bought into one of these overpriced 45-50W/ch amps and it doesn't come close to his 80W/ch amp with his speakers. Both are high current but the smaller amp just doesn't have the power supply hardware to deliver the goods at louder output levels and when the bass hits and is increased. The Yamaha has a much larger capacity transformer, bigger power supply caps with much more DC voltage at the rails. It's simple physics that the Yamaha is going to be better. That and the price of the Rotel is steep for what a person is getting. The Rotel is $1099.00 in Canada and that's pretty expensive for what it is. The Yamaha is $1000 in Canada and offers much more.The yamaha amp won't beat the Rotel A11 Tribute, thanks for watching
I checked 7 etailers in Canada and all are $1099.00 but UK £499 is better. I still think it's overhyped and overpriced.Rotel a11 tribute cost in uk £499 equal to 869 canadian dollars
The amp Is more than decent
Lol.. it was me that stated,Even though this site is focused on measurement of equipment , you'll still find people making bold claims ( 'eats xxx for lunch, etc. ).
The reason I listed the NAD here: recently had the opportunity to test a friend’s NAD 319 in my setup, with the Wharfedales, and the impression was quite strong. To my ears, the NAD was fuller and more clear in the mids (vocals, guitar, which I love as I listen to blues a lot), the bass seemed to be tighter (less boomy) and cleaner (more articulate maybe?) and the presentation was more forward, as in, while with the R-N301 the sound is more or less in line with the baffle, with the NAD was projected more in front of the speakers and closer to me. That’s the “feeling” I had, the best I can describe it in this “audiophile” jargon.All I can say on the subject is that for the past 15 years I owned Diamonds 8.4 (which are not the same as yours but close) and a NAD C372 (which again is just one generation over a C370 in your options)… And I really like the tandem!
Despite also having a number of more modern components (and significantly more expensive… though sometimes significantly less expensive too, eg an Aiyima A07 class D amp for $70), the Wharfedales/NAD are still heavily used and loved. And, while in a slightly smaller room, they are a worthy competition to their bigger siblings - Diamonds 11.5 and NAD 375BEE - so, sometimes I even prefer (like equally?) their sound (with some Roon-assisted room EQ’ing).
NAD C372:
- 2 x 150W Minimum Continuous Power into 4/8 ohms,
- 220W, 340W, 460W IHF Dynamic Power into 8, 4 and 2ohms, respectively
[Replaced power-supply capacitors and op-amps in my C372 4-5 years ago though.]
Just my $0.02.
The NAD 319 takes it to the next level up compared to the Yamahas you've mentioned. The NAD 319 has 8 output transistors per channel, more power supply capacitance, a higher rated mains transformer, better components like capacitors and generally is designed better all around. It should sound a little better. Not leaps and bounds but a little bit better.The reason I listed the NAD here: Inrecently had the opportunity to test a friend’s NAD 319 in my setup, with the Wharfedales, and the impression was quite strong.
The NAD C370 has 6 output transistors per channel, more power supply capacitance up to 20,000 micro Farad per voltage rail and higher dynamic power output.C370
In this case the two NADS are close in RMS power output. The C370 seems to have refined everything a little bit. The 6 transistors compared to 8 might indicate more current capacity although without looking up the transistor part numbers and checking their specs the actual difference is a unknown at this time. I think either would be a nice piece.So how would you rate the two? Do the fewer transistors make a significant difference?
SoundStage produced AP measurements of the A11 Tribute, which are much more relevant: https://www.soundstagenetwork.com/i...ts&catid=97:amplifier-measurements&Itemid=154
I guess you've already considered this, but I'm sure you may get your 803D shipped from Germany, France or Spain for cheaper than 1K€.Romania
I'm not actually considering changing the speakers, I like them. Just looking for a decent amp to pair with, as good as the budget allows.I suppose considering the speakers isn't out of the question?
Diamond 230 – WHARFEDALE
It looks similar to some other Diamond models, I can't find independent measurements for this one
Rated [email protected]/m. That's in the same sort of range as a number of other Diamond models which are often measured at around 2dB/W less at 1W/m, so not unreasonable to use 86 as the "real" number
Minimum impedence 3.7Ohm. I'd assume this number is probably correct, since it agrees with the measured output of similar Diamond models.
From the original post we may be looking for a peak output in the 85-90dB range, maybe more for comfort, at 3m.
Where does that leave us? Something like 150W into 4 ohms with enough current to go a bit lower? Several of the amps mentioned here would be plenty good enough for this. I'd look for a bit more.
That wasn't what I meant. Rather, nobody here appeared to have quoted the specs or any figures for the speakers, only amps. So I tried to do the sums for your speakers. (I may have overestimated the power requirement at a second glance, but we're in the range of the replacement amps suggested here, so nothing lost).I'm not actually considering changing the speakers, I like them. Just looking for a decent amp to pair with, as good as the budget allows.
