Advice on buying 2.0 PC speakers
lopblack
Hi everyone, I'm looking to buy a pair of 2.0 PC speakers. I've looked at various models like the Edifier M60, Aiyima S400, etc.; the main thing is that they shouldn't have overly prominent or boomy bass. Which model would you recommend for a budget of 150 euros? Thanks a lot.
The bass will be significantly affected by the speaker placement - it's not just down to the speaker. For PC speakers you will probably also have 'desk bounce'. Some speakers will have switches on the back to provide some compensation for this, or do it in an app. You can also run EQ on the PC - see the software EQ thread for options. Erin's M60 measurements look good within its limitations - he's done some of the other small Edifiers too. I've not seen any for the S400. Also check whether the Moondrop MM3A is within budget - I've not seen independent measurements but their own look good and their headphone measurements usually match independent ones pretty well. I suspect it'll be a bit over budget, but you never know with pricing in different countries, and what deals may be around.
Budget is for a piece or a pair? If for a pair, that'd be a bit tight - there are great budget speakers out there, but there's still a sort of minimum requirement to get to something decent.
I'd also look into Edifier mr4.5 and Moondrop mm3a
What do you have available? What brands or websites? What country are you in? Because I believe a lot of members here are in America, so our ideas may not be so relevant. Plus what @somebodyelse said about adjustability switches.
PreSonus and Kali offer excellent engineering and value in some models but pricing I have no idea. As a loudspeaker engineer I'll say don't get tiny woofers-even close on a desktop I'd want 5" more like 6" at least. And the tweeter should have a large waveguide, like the size of the woofer. THAT is the way to do tweeters today, many advantages of dispersion and power handling.
In your price range I think I would be looking at the moon drop also. They are a little beyond your budget but I'd suggest stretching if you can. $150 can't really get state of the art desktop speakers, that costs more like 10x, but I would say the moon drop speakers seem to get much closer than 10% of the way there. Edifier also has some strong options but not quite as refined from what I've seen.
I am in Italy, and the site where I usually buy is Amazon.
I don't agree with that advice. Just check what Neumann KH80 or Adam Audio D3V can do with 3.5-4" drivers.
Especially 6" monitors are getting really chunky. Proper placement and minimization of desk reflections would be much, much easier with smaller monitors.
For around 170 EUR you should be able to grab second hand Adam Audio D3V. They come with 5 years warranty so there is nothing to worry about.
IMHO value for money and performance-size ratio in this model is just insane. Amazing power handling, bass depth capabilities and functionality feature-wise.
For the desktop listening they offer like 90% of performance for 10% of the price.
IK Multimedia iLoud Micro would be a decent alternative if you want to support your local Italian company ;)
Someone asked a very similar question on Reddit a few days ago, from Europe too - wonder if it was you?
I was going to suggest the Adam D3V and I actually had a look to see if they were available secondhand at €150 or so, but it seems they aren't.
Yes, I have a Reddit account too; that's possible, yes.
I recently put the Edifier MR4 Mkii in my kid's playroom. I am very pleasantly surprised how good those little speakers sound. They cost the equivalent of $133 USD here in Vietnam.
