Jeff M.
- Joined
- Dec 30, 2023
- Messages
- 205
- Likes
- 105
Good morning everyone. So, the issue I have has not been a new issue it’s just been an issue for years and now it’s getting worse. So, I can tell the whole story but, I will keep it short because it’s a lot of work. So, basically we bought into my father and mother in-laws house 20 years ago. They live up stairs in their own house and we live down stairs in the original home. My father in-law didn’t want to buy a new breaker panel so to save money and put everything in the breaker panel he had already installed. He doesn’t remember because he is forgetting a lot now a days. The problem is he put the kitchen and bathroom and the main bed room on the same breaker of 15 amps. So, my problem is and has been that when my Keurig coffee make draws 12.7 amps at 1437.0 watts. It always causes a voltage drop from 120 volts to 114 volts to 115 volts and cause’s my led lights to flicker in these rooms.The break has not popped at all and I don’t want something to over load and heat up and. side a fire? So, My master electrician said get a power conditioner if you can’t afford an electrician to come and install an extra breaker in your home. So, my question is can I use a on line AC filtering unit like this (1st picture) to take care of my volt drop and my led lights flickering in certain spots? or should I buy a tripplite and call it a day? It will be bulky and out for people to see that’s the problem with the plug in device. What are you thoughts and is it better to put or piggyback breaker into that circuit so it is not over draw power? Things have changed in the last 40 years and we need more power and amps for newer appliances and devices for today’s electric. I tried to tell my father in- law that but, he kept telling me it is code. Thanks for your help Jeff
