Advice for getting volume control on my TV
vedirah
Hi,
My current setup is as follows:
TV -> Fiio BTA30PRO (optical) -> Fiio BTR7 (Bluetooth) -> Marantz PM6007 (RCA) -> Passive speakers and subwoofer
I'm using the BTR7 for the parametric equaliser. Because I'm using an optical cable from my TV, volume control is with the amp. However, I'm upgrading the subwoofer to an SVS PB1000. The sub has the feature of a high-pass filter on the line out jacks and I would like to use that feature. But if I were to do that, the signal chain would look like:
TV -> Fiio BTA30PRO (accepts only optical/S/PDIF) -> BTR7 (only bluetooth input) -> Subwoofer -> Amp (high passed signal) -> Speakers
In this scenario, how would I achieve volume control on the TV? I have the option to extract audio through the 3.5mm headphone jack on the TV and convert it to digital using a converter but what are the downside of that?
Hi @vedirah! Welcome to ASR.
To be frank, that setup sounds massively overcomplicated.
I'd suggest either
TV->HDMI ARC->WiiM Amp Pro->Speakers and Sub
or
TV->HDMI ARC->WiiM Ultra->PM6007->Speakers
with Sub plugged into the Ultra
The WiiM Amp/Ultra does both subwoofer integration and Parametric EQ, with volume control via the TV remote.
In addition, you gain the ability to stream music without turning the TV on.
In that case, you can control volume via the WiiM Remote or the WiiM Home App.
