@Noodles @mansr
My 2 cents on the Komplete Audio 6. First of all i use the Komplete Audio 6 MK1 , not the plasticky MK2. MK1 is built as tank. Reminds me of those vintage 60's amps.
Bought it probably 8 years ago and since then it's been
online 24/7 connected to my PC.
Not kidding. I turn it off only when something in my PC dies and i need to shutdown and change it.
I use it at the same time for my :
A) Guitar with (amplifier) outputs 1/2 to Yamaha's HS8
B) Home Audio System via non-amp outputs 3/4
Overall :
- Yes it has only up to 24-96 but TBH this is enought for most uses. For recording purposes it's more then enought if you know to master properly. For audio playing again more then enought. I've listened to some very very expensive autio setups over the past years and anything above 24-192 is total waste of breath. And the albums you can find and buy with this hi-res ain't that much
. But agian it depends on the usage i guess.
- Amp drive is enough for home studio use . I mainly split the AMP drive between KA6 and the HS8's amp. So both at about 12 o'clock and this is enough to drive my family crazy. As for Output's 3/4 i actually prefer them without AMP so that i can drive the signal fully from my home stereo amplifier.
- Latency enough. Unless you are Yngvie J. Malmsteen.
- Phono stage. Used it just briefly with some mid range AKG's . Was so so . But i would not expect wonders on this front from any up to high midrange Audio Interface. You wan't a decent phono stage 2k and above.
- SPDF -
I haven't used the SPDF's yet.
- MIC - I'm waiting for a XLR MIC as we speak.
i've used it on Windows 7 , then 8 and now 10. Have no issues whatsoever. It hasn't failed me once. I currently bought a second one second hand. You can find them very cheap now. I got mine for
80 bucks. i would suggest you find and grab a second hand one and if it sucks for your use case you can still get something newer more fancier.
Or if you haven't bought one yet and can wait a couple of weeks i can tell you if the XLR MIC works as well.
I also have Audiolab M-One in my B) use case and in MY home audio setup difference ain't mind blowing although they are not directly comparable. . Price is
I was recently considered upgrading to something more then the KA6 and even more then the Audiolab but i'm not very convinced the increase in audio quality in real use case usage, not just on paper, will justify the price for what i use it for.
