Hello everyone, I'm a complete newbie in both hi-fi (maybe I should say low-fi based on my basic setup) and in this forum, which I find extremely interesting. So please be kind about mistakes!
I have a very basic setup in my living room and I'm definitely not happy about it. I would like to do a step by step improvement, considering the very limited budget. As first step I would like to switch from the actual dac and amplifier to a better integrated amplifier with Bluetooth receiver or wifi. My budget is 100€.
Can you suggest me something better than my actual setup?(I don't have very high expectations based on the budget available, of course, but the best I can get with it). I was looking at SMSL, Fosi or Wiim, or else.
Thanks for the help!
Actual setup:
--> 2 Passive speakers tannoy mercury mx1
--> FX-AUDIO FX-502E amplifier
TI LM1036 Dual DC Operated Tone/Volume/Balance Circuit
ST microelectronics TDA7498 100-watt + 100-watt dual BTL class-D audio amplifier
TI TL082 or ne532p opamp (not clear from specs)
Impedence: 4-8 ohms
THD: 0.2%
SNR o: 73dB
-->bluetooth receiver esinkin
Qualcom CSR8620 chip
Actual setup:
| Enclosure Type: | 2 way bass reflex |
| Rec Amplifier: | 10 - 100 Watts |
| FQ Response: | 55Hz - 20kHz |
| Sensitivity: | 87dB |
| Impedance: | 8 Ohms |
| Drivers: | 1 x 25mm soft dome 1 x 130mm ceramic coated paper cone |
| Dimensions: | 298 x 165 x 220mm (W x H x D) |
| Weight: | 4kg / 8.8lbs |
| Year: | 2000 - 2002 |
Impedence: 4-8 ohms
THD: 0.2%
SNR o: 73dB
