Might give like 1 SINAD more than plain USB, in general there's a slight improvement, although sometimes more significant.I've seen some setups utilizing a digital to digital converter then connecting to a DAC. Is there any particular reason (besides DAC not accepting USB) to do such a setup?
I'm just going by the measurements so far when amir tested both USB and coax as with the EL Dac, Khadas tone board, ..What the technical reason an external USB-SPDIF converter would have better performance than built in USB?
In general it doesn't hurt to isolate into s/pdif, and often has a small improvement in measurements. Likely it'll sound the exact same as Usb so I agree one shouldn't bother, but generally there really was a small improvement looking at amir's work...Just saying "it may add 1 SINAD" doesn't make any sense. Why do people assume the USB interface on a dedicated spdif converter is always better than the USB interface on any given DAC? The people selling the device may want you to believe that, but there is no reason it must be true. If some vendor is selling both dacs and spdif converters, probably they use the exact same usb implementation in both (unless they one product is very old and the other very new).
Some usb interfaces are better and some are worse. The USB interface on a given DAC may well be much better than the one on a dedicated spdif converter, in which case you just degraded your signal.
You aren't avoiding the "overhead" of usb in either case. You're just moving it from your DAC to a dedicated device earlier in the chain. Digital audio over usb is still there. The only way to remove usb is to not have a usb connection at all in the chain, i.e. dedicated spdif outs on your source.
Digital to digital conversion (as long as it is done lossless) does not degrade the signal. The idea is to get rid of the ground loop and noise of the USB signal, that can be inherently "dirty". The goal by converting to Toslink using S/PDIF 24/192 is to remove all the electrical noise from the signal before going into the DAC.It only makes sense if your DAC doesn't have usb input, or the usb input on your DAC is so bad and usb input on the other device is so much better that you have to add the device to compensate.
Otherwise, adding more gear and conversions to the chain can only further degrade the signal or cause problems. There is no magic here.
7 year old posts but your right in any case.Digital to digital conversion (as long as it is done lossless) does not degrade the signal. The idea is to get rid of the ground loop and noise of the USB signal, that can be inherently "dirty". The goal by converting to Toslink using S/PDIF 24/192 is to remove all the electrical noise from the signal before going into the DAC.
