Adding VU meters to DIY Amps
Pluto
Harrow, UK
Whatever you do, don't be tempted to slap an unbuffered moving coil meter across an audio path as this can cause significant distortion.
kn0ppers
Germany
You would want something with a high impedance input that takes the audio signal and does whatever is necessary to drive the particular meter properly. Last time I checked there were different boards for this available from various sellers.
preload
California
There are a bunch of blue backlit vu meters on ebay if you want to take that route. I searched "McIntosh vu."
RayDunzl
Central Scrutinizer
Riverview FL
L
LondonLad
I'm curious about adding a VU meter to an amp and I came across this:
TEK vomit backlight
https://www.audiophonics.fr/en/scre...db-with-calibration-module-115-mm-p-8342.html
The 'vomit backlight' is 'white' and it comes with a 'calibration module'
The impedance is 650 ohm +/- 10%
Thoughts?
Fred, hello and thank you! Looks simple enough to hook up, but please anyone chime in if I'm overlooking something in terms of my assessment of how "simple" that hook up actually is.
