Adding Neurochrome's GUARDIAN-86 to Purifi Build
KenMasters
Denmark
Hi, first time posting but I've been following the forum for some time.
I recently purchased this 3ch 1ET400A based amplifier from Nord Acoustics. It works well in my setup and I'm very happy with it outside of a single niggle. Every so often it produces a relatively loud pop/crackle from one or more of the speakers on start up. Component power up order/delay or preamp volume doesn't impact the occurrence.
To address the issue I thought I might purchase 3 GUARDIAN-86 boards from Neurochrome. Would this be a workable solution? What would be the correct way to connect such a board to the SMPS1200A400?
groovybassist
Wendell, NC
You might want to message @tomchr directly - he's very responsive and typically on this forum daily. I have a Neurochrome Modulus-286 built by Tom that includes the Guardian-86 on each channel and the speakers are dead silent on powerup of the amp.
tomchr
Calgary, Canada
I'm surprised the Nord 1ET400A amp is producing pops on startup. I run my 1ET400A with the Neurochrome 1ET400A Input Buffer and the Hypex SMPS1200A400. It's dead quiet on startup.
I would ask Nord why your amp pops/crackles on startup. That sounds like a cold solder joint.
You can use the Guardian-86 I you wish. Assuming the auxiliary power supply shuts down when you turn your amp off, I would power the Guardian-86 from that supply. You'll have to change a zener diode to make the Guardian work with the lower voltage of the AUX supply, but that's the only change necessary.
You can also run the Guardian-86 from the main (±65 V) supply. Just change the zener diode (D4) to a 47 V, 1-1.3 W type. I'm happy to help you get going on this. Just toss me an email (via the Contact Us form on my website or by adding @neurochrome.com to my user ID here).
Tom
KenMasters
KenMasters
Denmark
I wrote to Nord about it and received a response from Colin saying that he had noticed a few pops he couldn't account for on the standard amps using OPA1612. The amp in question has a separate power supply for each module and considering the "pop" does the rounds across speakers, I thought it unlikely to be down to a single defect - but I'm certainly no expert in this field.
Tom
Thank you, I'll definitely get in contact if I decide to go this route.
tomchr
Calgary, Canada
That's disappointing. I would have expected more of a commercially available product.
At TI (and National Semiconductor) we'd call it a design oversight.
Tom
KenMasters
KenMasters
Denmark
Tom
Would a more elegant possible solution to my problem not be to swap out the input buffers?
Phorize
U.K
I have no axe to grind with Nord here but I’m not sure you should be having to add extra circuitry to a new £1600 amplifier to stop it harming your speakers. If there is a real prospect of speaker damage then it’s not fit for purpose IMO. It’s not great that the manufacturers response is ‘yes I noticed that my product is behaving badly, oh well’. My March p452 is silent on power up, in operation and on shutdown BTW.
tomchr
Calgary, Canada
That's another option. I know a guy who makes some really good ones. Let me know if I should put a word in for you. :)
I agree with that, but from Post #4 it sounds like the manufacturer is aware of the problem and has decided not to fix it. One possibility would be to see if they take returns.
Yet another option might be to hold the amps in mute/standby for long enough that the stock buffer can regain its senses following power-up.
Tom
KenMasters
KenMasters
Denmark
I think that is what I'll do. Colin did offer to take a look at it, but I'm not too keen on the idea of couriering it back to the UK from Denmark. From what I can tell, the boards are reasonably "plug-n-play"?
tomchr
Calgary, Canada
I've designed a couple of these buffers for OEMs. I have yet to hear of a complaint. So I tend to agree with your assessment that the buffers are "reasonably PnP".
At least the EU demands a fairly generous warranty term (two years). I'd push on that.
Tom
KenMasters
KenMasters
Denmark
@tomchr, I've received my Neurochrome buffers and am currently in the process of installing them. Each unit is connected to an SMPS1200a400 (J4>J2) - to confirm, would I be correct in setting the J6 & J7 jumpers to Regulated?
tomchr
Calgary, Canada
If you are not using the optional Neurochrome voltage regulators with the Buffers, you set J6 and J7 on the SMPS1200A400 to provide the regulated AUX voltage, yes. Leave the two jumpers on J4 of the Buffer in their default positions (1-2, 5-6).
Then connect J1 on the SMPS to J6 on the Buffer (6-pin power harness). If you need to create a Y to power multiple boards from the same supply, I do offer the SMPS Splitter.
Connect J4 of the SMPS to J2 of the Buffer using a 10-pin ribbon cable.
Connect the amp module to the 36-pin connector on the Buffer. That part is hopefully pretty obvious. :)
Connect input and output to the Buffer.
<tada.wav> You're done. :)
Tom
KenMasters
KenMasters
Denmark
Tom
Thanks!
tomchr
Calgary, Canada
No worries. Have fun building. I'd love it if you'd share some build pictures here once you get there.
Tom
KenMasters
KenMasters
Denmark
Some closure to this thread. After installing Tom's modules the same issue persisted.
While troubleshooting the issue prior I had tried pushing the delay as far as 10 seconds between my AVR/preamp and amp startup, it turns out even that wasn't long enough. I bought a network enabled plug for the amp and now switch it on manually only once all devices have powered up and the TV has picked up the signal from the Apple TV. Since doing that I've had no problems.
I'd like to apologise for any negative impression this thread might have brought Colin and Nord Acoustics. I've tried the amp with both the Nord and Neurochrome buffers and I'd be happy to use either. I'd also like to add that I was impressed with how neatly the Nord was put together:
MASKINEN
Sweden
I have similar turn on pops/ thumps in a 3ch Purifi based amplifier. Doesn’t matter if the amp is turned on manually or by a 12v trigger.
What kind of network enabled plug did you end up buying? I’m considering buying Tom’s protection modules which would delay the output 5 seconds.
Although the pops are not super loud with 20db of gain but they’re noticeable.
KenMasters
KenMasters
Denmark
I was premature in the quoted post, pops continued. I eventually did purchase Tom's Guardian modules and they did the job. You can still hear when a pop occurs, but it's muted significantly - I've been very happy with the results. Very simple to install.
tomchr
Calgary, Canada
Which power supply did you end up using for the Guardian-86? The +65 V or the +12 V?
Tom
tomchr
Calgary, Canada
You might get better results if you tap into the +65 V instead. It all depends on which supply collapses first.
If you use the 12 V trigger, you can also power the Guardian-86 from the trigger itself. It only consumes 6 mA. That way you're guaranteed that the output will be disabled as soon as the trigger goes away.
OTOH, if the pop is on start-up you're better off using the +12 V or +65 V.
If the preamp is making the pop on startup there's not much you can do about it other than delay the turn-on of the power amp.
Tom
