I have a conventional 2 channel stereo with a separate preamplifier and amplifier. In several other threads I've gotten a lot of advice and help in placing my speakers & MLP as well as room treatments. I still have a couple of deep nulls left that I'm going to try and correct by adding a pair of subwoofers. My initial placement is going to be at the center spot on each side wall which is one of the suggested positions by Harman and SVS. There are other suggested positions I'm going to try and I've already done a casual sub crawl. For one reason or another, perhaps the shape of my room, the Roon Room Simulator doesn't seem to give results that match the actual measurements so I'm no longer trying to use that. I don't want to spend a lot of time trying out and experimenting with different things only to post here and find out nothing I'm doing is useful. With that in mind, I'm starting with one sub centered on the right wall. I'm driving the subwoofers with the unbalanced outs on the preamp. I'm using the settings SVS suggested for my speakers (Wilson Audio Sasha ll's). They recommended a Low Pass Filter Frequency of 50 Hz and a Low Pass Filter Slope of 24 dB/octave.
I started out with this process by @Keith_W.
1. Set up the mic at the listening position.
2. Set up REW's generator to play pink noise from ALL the speakers.
3. Pull up REW's RTA view.
4. Adjust the phase of your subwoofer until the RTA is as flat as possible.
@staticV3 helped me with the settings for the Generator and RTA
The SVS subs can change Phase 1 degree at a time but I only tried 0 & 180. Again, because I want to make sure the process is right before I spend a lot of time on it. To me Phase 0 looked better so that's what I went with. The subs also have optional Auto EQ built into them. I tried both ways and the frequency response of the Auto EQ looked better to me than the non-EQ so that's what I went with.
Actually, now that I take another look at the graph of the Mains & Sub, with and without Auto EQ, maybe the dip of the Auto EQ is worse than the peak of without. In any case, I would appreciate it if someone could take a look at this and help get me pointed in the right direction. Thanks.
