Adding a 5th subwoofer to my setup
olds1959special
Los Angeles, CA
This is my bedroom setup with Hafler circuit implementation using a MiniDSP. The subwoofers in the front are panned LCR, and the rear subwoofer is playing the ambience recovery channel. The front subs are 12" L/R and 10" C, and the rear sub is 10" and I am hoping to stack a 8" sub on top of that one. I think I could calibrate them to sound okay with the gain and LPF, although they would be set to 0 phase to match the rear speakers, and probably turned down as not to overpower the front.
Speaking of the rear channel only - would it be possible to use the 8" and 10" subs together if setup properly? I assume yes although I'm not sure what the advantage would be, except maybe to potentially smooth out the bass response a bit?
Hopefully I'll have the extra 8" sub available to put to use tomorrow and I think it will work this way!
From AI:
Auditory envelopment bass refers to the sensation of the low-frequency sound, or bass, physically surrounding a listener, which is a combination of hearing and feeling the sound. It is distinct from simple bass reproduction and is achieved when the reflections of low-frequency sound in a room create a sense of space and pressure that is felt not just by the ears, but also through bone conduction via the skeletal system.
Key aspects of auditory envelopment bass
  • Dual perception:
    It's a combination of both aural (hearing) and physical (feeling) perception, where low-frequency energy is felt as pressure, vibrations, and a sense of being immersed in the sound.
  • Bone conduction:
    The skeletal system can vibrate in response to the low-frequency pressure waves in the air, acting as a complementary "ear" for bass.
  • Room acoustics:
    A room's reflections are crucial. In a properly treated room, reflections from the walls, floor, and ceiling are carefully managed to avoid creating "muddy" sounds or "hot spots" of pressure.
  • Temporal envelope:
    The way a bass note's attack and decay are managed is critical for creating envelopment. A proper attack and decay rate maintains the integrity of the sound wave and its perceived depth.
  • Emotional impact:
    Auditory envelopment, especially in a stimulating and emotionally powerful way, is a key aspect of high-quality audio experiences, like those found in concert halls or a well-treated home theater.
How it's different from standard bass
  • Standard bass:
    Typically involves just the direct sound from speakers, with less emphasis on the subtle physical and reflective components that create the envelopment effect.
  • Auditory envelopment bass:
    Requires careful control of the sound field, often involving multiple speakers or a deeply designed acoustic space to generate the full experience of feeling the bass surrounding you,
