Pieter1267
- Joined
- Nov 20, 2024
- Messages
- 181
- Likes
- 99
So I finally pulled the trigger and received my first new custom build SKRAM subwoofer. Its a ported horn design cab for high output over a long range and versatil in setup with 4 adjustable ports to change the character from its original mid bass chest punch base to a more low extension for home theater purposes.
Ive really gotten convinced that higher crossover work best, even with big main floorstanding speakers. These SKRAMS measure flat way past 110hz and deliver up to 130hz up to 90% still.
Because im only using it for music i think im gonna keep full open ports or just one port blocked. The room gain is such that even with 1 port blocked i sometimes need to turn down the bass control on the pre amp a notch. It could also be that i have just one cab and with 2, the bloaty feeling might be more controlled. I also suspect it might be only with bad produced tracks.
That said already this one SKRAM is the best subwoofer ive ever had, and blows my previous 2 Dayton Ultimaxes out of the water. Its loaded with a B&C 21DS115-8 and gives my inuke 6000 a good workout. The mid bass is just awesome. At volume you feel and hear a big air mover at work, like an airplane taking off.
Ill post some measurements later. Some extended considerations on these SKRAM designs when i have number 2 and better comparisment.
Here are some pics. They are big yet not as big as keystone, th18 or gsg devastator. The smallest near PA level subwoofer with hifi quality delivery. Josh Ricci designs are fantastic.
They are still measuring 91x83x60cm and weigh about 90kg plus driver. Look next to my main speakers the F208 Revel. Not sure how to get them to @amirm if he would like to test them
