Add fans! Do as Fosi does, not as Fosi says
whazzup
These little amplifiers can get toasty. No manufacturer will tell you their products are too hot for the tiny enclosures, but let's watch a little clip from Fosi Audio themselves. Read between the amps!
Amplifiers can and do get hot and needs a little breathing room, so what's the news here?
The video is a good data point. Not just more breathing room but may even need some extra help.
Inefficient amplifiers can and do get hot. ;)
This bad boy gets hot.
and, interestingly, the heat's not mostly from those glowing filaments -- it's wasted energy dissiplated by the plates of the single ended (Class A) triode power output tubes! Plus some from the power supply and the transformers' inefficiencies, too.
A Class D amplifier, properly designed, implemented and loaded, should not get hot.
We're talkin' thermodynamics, here! Heat is waste (except for a purpose-built heater, like a nuclear reactor)!
Guess it depends on what we do define as "hot"? Of course tubes gets _really_ hot and AB quite toasty, but none of my class D are cool, they are definitely hotter than the air around them but no problem touching them. Though the TPA3118 amps I have are definitely cooler than my Topping Mini 300 and IRS2092.
Again, tubes don't have to "get hot" -- it depends on their operating points. A vacuum tube amplifier can be surprisingly efficient and operate surprisingly cool... we'll overlook the infamous Carver "Crimson" amp* ;) -- but McIntosh's fabled Class B power amps (e.g., the MC-225) are actually quite efficient, and even the power tubes are operated under conditions that permit their service lifetimes to be quite long.
____________________
* https://www.audiosciencereview.com/forum/index.php?threads/carver-crimson-275-review-tube-amp.29971/
I agree. But on the other hand, I can see how in the pursuit of bigger numbers for marketing supremacy, these chip amps' thermal loads can start to outgrow the current form factors. Living in the tropics and running them for very long hours, a few more dollars and some fan noise doesn't seem to be a bad insurance policy.
I've got the Fosi V3 monos which Amir remarked on being highly efficient in his review yet they still get pretty toasty to the touch, it's just what happens when you've got triple digit watts going through; they've never gotten warm enough for me to be concerned but I also wouldn't stack them
Yes, I reckon (see "suspect" qualifier below!) you're right on most/all counts!
I can only speak for myself, but I don't understand the abhorrence of "muffin" type fans! They are very quiet - and there's always the old trick of running appropriately spec'd fans at reduced voltage, which of course reduces airflow but also renders them nearly silent.
I don't doubt that there are ultra-fastidious people in the world with purpose built listening spaces (most likely for home theater) that are sufficiently quiet that a fan is a distraction. I suspect (not data driven! :facepalm:) it's a small percentage of total.
My streamer amp is 12" x 12" x 4" approx. running Hypex.
I can run it very loudly all day and the case gets a bit warmer than ambient.
Should I buy a Fosi fan to get it back to ambient-ish? Is that going to cost £234, plus the £234 PSU to go with it? I've no idea.
I was actually surprised at how cool the glass envelopes of tubes like 45 and 300B seemed to run, compared to say, EL34 or KT88, despite the impressive glow of mesh plate designs. But in terms of total BTU output, dunno: Maybe the big glass simply dissipates heat better?
