Add bluetooth to an amp
gasolin75
Denmark
Mabye i have asked this before but i got a new amp Marantz PM 6007
I didn't find any cheap amps besides the wiim amp that also has bt and usb
So my question is what to get if i want bt and mabye a better sound card or dac
24bit and 192khz if it's a dac,usb in, bt 24 bit and 48khz is aptX HD, i don't think it's higher from bt
SMSL PS100 super cheap has both (usb and bt (no antenna) + dac), analog out but no aut on/off
FX-AUDIO BL-MUSE-01 PRO+ Bluetooth 5.1 Receiver QCC3031 aptX HD under 40 euros coaxial out
HALL AUDIO Hall Connector Bluetooth 5.0 receiver under 60 euros
Inakustik Premium Bluetooth 5.0 receiver 90-95 euros
IFI AUDIO ZEN AIR BLUE Bluetooth 5.1 Receiver around 100 euros same price as a wiim mini with bt
cdplayer and pc are connected to toslink and i only have 1 digital coaxial in on my amp available, analog im fine
When i stress test,benchmark my pc or making food in my kitchen, i just wanna be able to use my phone to play music, control the music using my phone with bt, not use it 24/7, that's why it's from super cheap to no more then 100 euros ish
Poor performance:
SMSL make two other budget DACs with Bluetooth input: C100, PS200
These perform a lot better than the PS100, but just like it, they only support basic SBC Bluetooth audio.
SMSL's cheapest standalone DACs with HQ Bluetooth input are the DO100, SU-6, D-6, D-6S,
Im not going over 100 euros if so i could have bough a better amp with bluetooth,better digital in (chip)
Even at 100 euros i think it's a bit to high price for what i want wiim mini or IFI AUDIO ZEN AIR BLUE Bluetooth 5.1 is what i max want to spend
Since your Marantz has a DAC built-in already, I think the smartest thing would be to buy a purely digital Bluetooth receiver.
I can recommend the BerryBak BEA1: https://store.sure-electronics.com/product/796
It costs $30 and uses the very latest Qualcomm BT receiver with support for basically every imaginable Bluetooth codec, including LDAC, BT LE, LHDC, and even aptX Lossless.
I've used it for Bluetooth-related audio measurements and it's been flawless.
Wow! Thank you. I can add bluetooth to fosi V3 via SU-1 using BEA1.
Did you consider the Qudelix 5k?
It's a headphone amplifier with parametric EQ and BT, but you can just connect it to your amp with a 3.5mm to 2x RCA splitter. Around €150
Bluetooth connection is rock solid and it has tons of features that let you customise it to your liking, and you can do room correction if you want using the parametric EQ. And if you decide to get something else later, you have one of the best portable headphone amps.
I used one for my speakers temporarily while considering the Wiim Ultra. Ended up with a Raspberry Pi and Camilla DSP instead. So happy I didn't waste €400 on a Wiim Ultra.
But the BEA1 costs around 50/55€ here in Europe.
$37 (=34€) shipped to Germany, directly from sure-electronics:
The point discount is applied for every new (first time) customer.
If no one minds, I'd like to bump this. Perhaps I can help with some details and, maybe, someone can help me with some others.
This is what I've done:
My amp has power out as amps used to. I took a plain USB-A smartphone charger to plug in and power up a Bluetooth receiver. It has a 3.5mm jack. So I took a 3.5mm to 2xRCA adapter and I plugged it in Tape in input on my amp.
Far from ideal, but I don't notice anything wrong with the sound.
One single problem I have is that everything works fine for an hour or two, sometimes three, but then it starts with the hick-ups. Sounds like you hit pause for a short while. It loses the signal completely and than keeps on running and then again, loses the signal. Just like streaming interruption. When you try to listen to something and your kids are going wild with online gaming so you get interruptions.
But how come they start after a few hours of listening? What can cause this? Is it perhaps that some processes start running in the background and your resources get spent on those?
I never heard of WONDOM, where in the world are they?
My computer is in another room (upstairs, in the office [I currently use a several year old Bluetooth setup (no LDAC, only running aptX) so I would need a transmitter or transceiver (even better) and receiver. There are two walls and
Do you have any recommendations for those?
Thank you for your consideration.
I've tested both USB and Bluetooth(LDAC) with optical connection and works perfect:
