- Joined
- Feb 5, 2019
- Messages
- 3,688
- Likes
- 4,069
Hi,
I am considering adding a subwoofer to my Aria 906, as I listen to electronic music mostly.
My living room is 16m² only and I won't blast the sound. I just want to hear all the frequencies (down to 30 Hz) of my records.
Here is the frequency response of the Ariua 906's as measured by Soundstage:
https://www.soundstagenetwork.com/i...cal-aria-906-loudspeakers&catid=77&Itemid=153
I'm thinking about
1) either just put a sub with a 12 dB / octave low-pass filter at 80 dB
or 2) add a miniDSP 2x4 HD and put both a low-pass filter for the sub and a high-pass filter for the mains at 80 dB with steep slopes (96 dB/octave) FIR.
As for the sub, Focal offers two options:
S 300 P, which is ported
+/- 3 dB between 36 Hz - 160 Hz
- 6 dB at 29 Hz
around 400 €
and
S 1000 F which is closed
+/- 3 dB between 24 Hz - 200 Hz
- 6 dB at 22 Hz
around 800 €
A guy on a forum said he had to return the closed one because it is not good for home cinema / house music, being too directive.
I can of course also go with anything else.
What are your views?
Cheers.
I'm thinking about
- 6 dB at 29 Hz
around 400 €
and
- 6 dB at 22 Hz
around 800 €
Cheers.
