ROOSKIE
There are a lot of on axis frequency errors that can never be fully fixed by DSP.The off-axis dip around the XO point can't be cured by DSP. It's a function of the crossover frequency, slope, and centre-to-centre distance between the drivers.
For a given XO frequency and C2C distance, the magnitude and (in particular) bandwidth of the dip can be reduced by using higher-order filters, which is certainly cheaper/easier to do with DSP. However, beyond a certain limit there are other trade-offs involved (increased group delay and/or ringing).
Or are you talking about the on-axis dip at the crossover point? This is certainly something I would expect DSP equalization to remedy. Perhaps Adam was going for a house tuning here. It is a bit surprising IMO.
Such as edge diffraction from the woofer surround, the woofer dust cap or lack of dust cap, some cabinet edges, some tweeter edges ect.
DSP is amazing but something things will just never be fixed.
In fact driver surround, edge diffractions and others of these type of errors are often less when off axis then on. Or at least the changes are give and take.
You also have to factor that as a business model the budget speaker needs to have some flaws to justify the more expensive models. Not many companies can work well if it is truly going to be a race to the bottom. That will not work in our type of economy where many folks need to be employed and companies need to structure multiple lines of products in order to be able to stay profitable and thus employ people.
