- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,403
In Adam's manual in the speaker positioning section of the T Serie, they state at page 8 "For the flattest bass response, each monitor should be placed at least 16 inches from the nearest wall". That's a figure more familiar to me for rear firing ports but I don't really have the rigorous metric to caracterise what is an optimal distance.
That seems correct for this speaker, but it's not because the port is rear-firing. Rather, it's because the speaker has an anechoically flat bass response, i.e. it is not designed such that its bass is intended to be reinforced by the front wall. This would also be correct if the speaker measured the same but had its port on the front.
Have a look at the frequency range in which the port is making a dominant contribution to the speaker's output. It's really only below 60Hz, although arguably it continues making a useful contribution up to just above 100Hz.
The wavelength of say 80Hz, which is already well into the frequency range in which the woofer's output is dominant, is about 14 feet. In centre of the port's operating band, at around 42Hz, one wavelength is around 27 feet.
There is just not going to be a more than negligible change in the speaker/boundary surface interaction at these frequencies when we are talking about changes in distance of one or one and a half feet... Indeed, the question of where on the speaker the port's exit is located is just not going to be relevant at all at these frequencies (although the location of the port inside the box is important, for reasons unrelated to this).
There would be a potential change in the speaker's output, however, if the speaker were placed so close to the front wall that the port's effective internal volume of air were increased. However, given Amir's description of the setup in post #90, it seems that there was adequate clearance for this not to be an issue.
Quite aside from questions regarding the location of the port, however, he did of course have the speakers suboptimally close to the wall.
