Here is my take on the EQ.
The raw data with corrected ER and PIR:
Score no EQ: 4.2, not great
With Sub: 6.45
Spinorama with no EQ:
- The response is not that smooth
- The HF is obviously too hot
- smooth DI will help for EQ
- It would be nice to see the impact of the built-in EQs and check wether that can be helpful.
Directivity:
Nice directivity
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help smoothing things out.
It will definitely help with the HF.
EQ design:
I have generated two EQs. The
APO config files are attached.
- The first one, labelled, LW is targeted at making the LW flat
- The second, labelled Score, starts with the first one and adds the score as an optimization variable.
- The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
- Quite a few sharp PK, would need careful ABX evaluation to verify if they are actually beneficial.
Score EQ LW: 5.57, already a nice improvement
with sub: 7.86
Score EQ Score: 6.29
with sub: 8.49
Code:
Adam T5V APO EQ LW 96000Hz
December072020-135609
Preamp: -1 dB
Filter 1: ON PK Fc 309.5 Hz Gain 1 dB Q 1.5
Filter 2: ON PK Fc 815 Hz Gain -1.5 dB Q 3.97
Filter 3: ON PK Fc 1349 Hz Gain -1.85 dB Q 5.29
Filter 4: ON PK Fc 7805 Hz Gain -0.7 dB Q 3
Filter 5: ON PK Fc 5738 Hz Gain -2.26 dB Q 3.87
Filter 6: ON PK Fc 10291 Hz Gain -2.06 dB Q 1.15
Adam T5V APO EQ Score 96000Hz
December072020-135241
Preamp: -1.2 dB
Filter 1: ON PK Fc 322.5 Hz Gain 1 dB Q 1.05
Filter 2: ON PK Fc 826 Hz Gain -2.42 dB Q 5.8
Filter 3: ON PK Fc 1353 Hz Gain -1.12 dB Q 7.25
Filter 4: ON PK Fc 1680 Hz Gain -0.95 dB Q 5.25
Filter 5: ON PK Fc 3285 Hz Gain 1.7 dB Q 9.23
Filter 6: ON PK Fc 4589 Hz Gain 1.7 dB Q 9.14
Filter 7: ON PK Fc 12913 Hz Gain -1.2 dB Q 3.75
Filter 8: ON PK Fc 5470 Hz Gain -3.51 dB Q 2.91
Filter 9: ON PK Fc 8857 Hz Gain -2.06 dB Q 1.56
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal, still very slightly ascending once EQed
Radar no EQ vs EQ score
Large improvements
The rest of the plots is attached.
My personal EQ was generated before looking at Maiky's, this one seems to be a middle ground in between both of Maiky's EQ's.
It is quite close to their score EQ but as I use my speakers in both near and mid/far field I try to strike a balance between listening window and predicted in room.
Some thoughts:
Target is just to show the linearity and slope of the predicted in room response.
I prefer the sound with EQ in listening tests but did not test audibility of every filter individually.
Bass boost has been measured in room, it adds more bass extension but is at the limit of what is possible with this ported design.
Boundary effects will also affect the bass extension and in room EQ is always needed.
Tried to use the same color scheme as Maiky so it is easier to compare.
I am not sure my current preference rating calculation is the same as Maiky's so I did not add a preference score.
I presume that unit to unit variance will be bigger then the differences between my EQ and Maiky's Score EQ.
Spinorama:
Zoomed in:
On axis (red) and listening window (lime green), note that the listening window has a slight downwards slope:
With bass boost:
Preamp: -3 dB
Filter: ON PK Fc 50 Hz Gain 3 dB Q 2
Filter: ON PK Fc 315 Hz Gain 1 dB Q 1.1
Filter: ON PK Fc 805 Hz Gain -1.5 dB Q 5
Filter: ON PK Fc 1350 Hz Gain -1.4 dB Q 5.5
Filter: ON PK Fc 1720 Hz Gain -0.7 dB Q 5.4
Filter: ON PK Fc 3340 Hz Gain 2 dB Q 7.5
Filter: ON PK Fc 4585 Hz Gain 3.6 dB Q 7.5
Filter: ON PK Fc 5290 Hz Gain -3.6 dB Q 1.8
Filter: ON PK Fc 8770 Hz Gain -1.4 dB Q 2.6
Filter: ON PK Fc 12755 Hz Gain -1.6 dB Q 1.5
Without bass boost:
Preamp: -1.2 dB
General advice, when using windows and equalizer APO, use a pre-cut of -0.2dB on all devices to avoid CAudioLimiter.
A debate has been long raging in the audio community that Windows isn't fit for use in a high resolution audio system. Sceptics counterargued that bits are bits and Windows audio degradations are a figment of an over-active audiophile imagination. I decided to investigate this as I kept...
www.audiosciencereview.com
-Ype
