I've had both the T5V and T8V and neither have any hiss or at least it's been so low as to not been noticeable. I've built my own DAC which feeds balanced audio into them and would suggest to anyone having hiss issues to look at that aspect.
In terms of sound the T5V has the T8V beat in punchy mid-range which of course is expected from the 5" driver. There's no substitute for 3 way speakers, and naturally the T8V wipes the floor in the bass department. It's so good that despite Adam Audio trying to hide it by using different db/A measurements the low response is equal to the S3H. Only the S5* goes lower. I tried the T5V with the T10S subwoofer they offer and it doesn't work there's the usual missing and/or phase mismatch at the lower end. The T7V + sub may be the sweet-spot but I haven't tried it. With T8V the sub becomes mostly pointless.
One thing I would like to mention is the claimed wattage which is a lie. If you open them up you'll find a Texas Instruments ADC feeding into a combined PCM + Amp, the chip also being from TI. This on the T8V is 50W rated. Adam cheaped out a little on both components, Texas do better versions with higher SNR instead of the 108db/A they went for and they only cost a tiny amount more. Because of this for most higher end DAC's the speakers becoming the weak link in the chain. They do sound great though.
Also most manufacturers are saving AES/SPDIF for their premium priced speakers. For literally $1, Adam Audio could have bought TI's SPDIF chip and fed PCM directly into the AMP chip thus bypassing the ADC.
