After two months of using them I would like to give minor advice for people who want to get them for desktop multimedia like me and skim this thread for some useful info.
If you are gaming, consider going balanced, with something like focusrite solo 3rd gen(I think it's the cheapest decent DAC with balanced outs and a volume control around), or if your DAC can go optical do it. 200w+ GPUs under 100% load will make electrical noise through USB. Just like everyone predicted here, but it's not inherent to Adams, JBLs I had did the same.
On gaming side, if you are coming off headphones, spatial audio with speakers is surprisingly very close to headphones and at times superior, my biggest surprise. Honestly if I could afford it I'd get top tier monitors just for gaming, I bet audiophiles would spit on me for that.
The hiss. It's there, it's not JBL 305p annoying, but it's there at 40cm, at 1m it goes away more or less. At 3o'clock on gain knob it's bearable even at 30cm, but USB DAC I have(MOTU m2) struggles to push volume on that gain so I keep them at ~1m away.
The most important part not emphasized strongly enough in speaker threads. Consider doing room correction. It's night and day difference. UMIK-1 is good, but getting something like Behringer UMC22 and ECM8000 mic would cost around $60 and much faster compared to $100 for UMIK-1 and shipping from Hong-Kong. REW is free. I can't describe how much it improved speakers in my room. There is a whole branch on the forum if you want to know more, topic is an abyss of knowledge so keep it simple, turns out simple is the best for this thing. It's a slippery slope of endless measurements and corrections, but's it's worth it, so much worth it.
-3db treble shelf EQ, to my ears is a must, I think with the treble switch at -2db too. so It's more like -5db EQ.
What I'm trying to say, If you are afraid to EQ, or use speakers without a computer consider something else. But if you are ready to tinker you can make them sound real good. My target was low, just Sennheiser hd600 sound, and I think I'm 90% there.
Ah one last thing, please do not listen to youtube comparison demos, t5v sound nothing like it even without corrections.
