.....I know, I know. You think that step deep is because the speaker went into compression. Not so. The levels were already lower than what I use with passive speakers. But to stay on the safe side, I ran the entire ~3 hour measurement at less half the level and got the identical outcome. Levels were extremely low in the second try and the shelving behavior was there. The frequency is too low to have anything to do with directivity. I suspect this is a correction curve applied to the speaker on purpose, hoping that the room gain fills in the rest..... .....Interesting enough though, we see a variation in response at the same point I measured a rise in response. I wonder if they used some kind of near-field curve to stitch here and the gain level is wrong there. They do show a tilt up the same way I have it at higher frequencies..... .....I plan to contact Adam and see if they have an explanation. And am open to suggestion and comments you may have on what may be going on.
No, the MDR-7506s are completely different. Their main pluses are an excellent midrange and rugged build. I've been using and abusing them for over a decade with no problems.I see your work rig uses 7506's, you find them to be a similar signature as the Adam's? I was thinking they'd be just the opposite from past experience with those cans.
I'll eventually sell these ADAMs and get new 'phones, but I'm not sure what to go for yet. I'm hoping ASR will fill that gap for me sometime soon.
The bass driver looks very much like a variant of an Eton hex-core driver. (Basically just an inverted dust cap as customisation.) Eton also make an AMT tweeter, and I bet they custom make both these drivers for ADAM.
Anyone knows the point of ribbons over good metal domes other than marketing/uniqueness? I'm pretty sure the distorsion is very low on both while the dome doesn't have ribbon's bad vertical directivity.
Thanks, I'm not their target market, but I wouldn't mind having a go at those headphones!At the moment there is a chance to win a pair of these beauties on their website
So it would be great if you could take part in the survey. Among all participants, we are giving away ADAM Audio products worth 4.500 $, including a pair of ADAM Audio S2V and T7V studio monitors as well as SP-5 headphones.
@ BYRTT
Nice what you do with the data.
Sorry, nope.The bass driver looks very much like a variant of an Eton hex-core driver. (Basically just an inverted dust cap as customisation.) Eton also make an AMT tweeter, and I bet they custom make both these drivers for ADAM.
Correct or even signs of distortion.Didn't run out of power means didn't clip right?
I started wondering, where is NFS's transition of soundfield separation-direct response? Perhaps the level matching in software just didn't do it right. This step can be seen in many other speakers too, but not so sharp.
Hardly an "allegation". I'm not suggesting malfeasance. Eton are one: German. Two: produce extremely high quality drivers. Three: have a propriatory cone design using a hex core laminate that is very characteristic in appearance, and apparent on the ADAM bass driver. I would be surprised if a niche manufacturer of high quality speakers in Germany didn't at least consider a relationship with Eton. Such relationships are pretty common.Since we're a science and fact based forum what would be the facts behind your allegations? As @KSTR wrote, Adam, Hedd & Eve all develops their own propriatery drivers and they're all among the producers I trust.
/Cheers
