Thanks! You just saved me a few hundred $
The dsp and digital input are not optional. Saving means a different speaker. No matter what input.
What were you planning to buy?
The Lake People DAT RS 05. Seems like you have a digital volume control knob as well so seems like the perfect solution for the S2Vs!
Ahh... The classic dusty woofer
Yeh, I saw it just the same but didn't want to mess with it.Ahh... The classic dusty woofer
I used them to listen to music all the time. No problems with output. My only complaint was the vertical directivity and, now that Amir's uncovered it, the bass shelf (not that I had any inkling it was there in my in-room measurements).Is anyone else using these for listening to music instead of mixing/mastering? Would like to know what your thoughts are regarding their performance as a "Hi-Fi" speaker.
What Preset do you use them on for music listening? I keep switching from Pure to UNR as the later has more satisfying bass but Pure has more detail. I don't have the necessary equipment to tune them to my room so not sure what to set them on.
I used my own preset to tone down the highs a bit and to EQ a few room response issues. So most similar to Pure. I didn't like UNR because of its U-shaped boost, which is fatiguing to my ears.What Preset do you use them on for music listening? I keep switching from Pure to UNR as the later has more satisfying bass but Pure has more detail. I don't have the necessary equipment to tune them to my room so not sure what to set them on.
This is a very important review. The product is in a category where there is a lot of interest. I would love to see the popular, widely available and much more affordable, at $750 each, A7X tested.
Yes, Is that each? I found them in Canada for $2359.00 but the retailer's web page does not indicate quantity.
EDIT:
wowowow $4718.00 per pair in Canada
You can get them for much less from Anderton's in the UK. I got a pair for just £805.66 shipped to the US.Yes, ton of people interested on a7x measurements, they are 1000€ a pair
LOL.Being smart, I put in a random serial number and got through.
No, it's not. It's 919.57€. Getting the cables for your region would cost you probably 10€ or less since they only need the ubiquitous C13 female termination you would find on most home and office appliances.That is more than 1000€
