ADAM Audio D3V specs price ?
PIR doesn't really matter with near field like this, you're so close direct sound tends to takeover.
Reactions: Ype
It will matter for people like me that also want the ability to listen in mid/far field even if it's at low volume, as the D3V's are portable.
Luckily the dip looks like it will be just outside of the massive 2 kHz dip of stereo (phantom center), which reflections from the room will partially fill in.
Nothing else I can say about it without testing it for myself. ;)
Am I right to assume that there is no perceivable input lag on these speakers? Even if they do ADC/DSP/DAC?
I can't get over the fact that they used such a cheap usb-chip/dac that supports only 16/48. Should have gone with the industry standard Xmos chips, have selector for UAC1/UAC2, and lost the headphone output if that'd meant skipping an unnecessary ADC step. (Or redesigned the the headphone out around that). But if the analog inputs have no input lag, then I can live with that.
Erin measured 2ms, likely from analog input, so imperceptible:
Source
Latency specified by manufacturer is 4 ms. I didn't tried them with DAW or guitar yet but I can imagine it wouldn't be a problem in any situation.
4 ms delay is comparable to sitting approximately 1.36 m farther from the speakers.
I would say D3V are backed up by really solid engineering considering the costs, performance and serviceability/complexity.
ADCs and DACs built into ADAU1701 DSP chips are completely adequate, USB input is just a nice bonus.
Using jellybean PCM2704 allowed them to keep costs and complexity down.
General purpose MCUs suitable for USB UAC and proper software-based DSP are relatively new idea (lately popularized by e.g. DX1 II or DSPi).
This approach requires much more SW development compared to using off shelf DSP chip. Back in the day when D3V were developed and released, powerful enough MCU chips were also considerably more expensive and harder to get due to COVID shortages.
Maybe someday we will get new D3V mk2 with UAC 2 and more elegant signal chain without unnecessary analog to digital conversion but imho this is nitpicking. Current version in my humble opinion is providing insane price to performance ratio and is perfectly fine as is.
