Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,225
- Likes
- 11,004
DamnNope.
If i knew this is an issue I wouldn't have bought them
DamnNope.
Damn
Sounds like an issue with your phone and/or the USB connection. Just tried with my Android phone connected directly to the speakers, worked just fine. No pops.I'm having annoying pop sounds when music is not playing when connected to my android phone via USB C
Does the firmware update solve this?
ThanksSounds like an issue with your phone and/or the USB connection. Just tried with my Android phone connected directly to the speakers, worked just fine. No pops.
Maybe check the audio settings? Could be trying to output at a bit-/sample-rate that the speakers don't like. Might have to go into the phone's "developer options".Thanks
Not sure what's the problem because it's a relatively new S25 Ultra
ThanksMaybe check the audio settings? Could be trying to output at a bit-/sample-rate that the speakers don't like. Might have to go into the phone's "developer options".
Maybe? I got mine at the end of last year, and they seem to have come with the firmware already updated as I can enable and disable auto-standby as described in the change log. They've been used with several android phones via USB but I don't remember any unexpected popping.I'm having annoying pop sounds when music is not playing when connected to my android phone via USB C
Unfortunately I don't have any windows device so I can't update themYeah, if it's not already on the updated firmware it certainly can't hurt trying it to see if it addresses the issue. I updated mine as soon as I got them.
You can also use a Mac. But is this a thing where you don't own any actual computers, only mobile devices? Or are you one of those penguin lovers?Unfortunately I don't have any windows device so I can't update them
I only have android devices (phone and tablet)You can also use a Mac. But is this a thing where you don't own any actual computers, only mobile devices? Or are you one of those penguin lovers?
No measurements, no way to know. I would guess almost certainly not.Are the Ruarks worth twice the price?
