Ogunya
- Joined
- Nov 12, 2021
- Messages
- 39
- Likes
- 11
this you can use. you need plug the adam powr suppky correct for +/- to the input. then you need a correct cable to the adam d3v. but i dont believe that it change something in sound if you hear no strange noise with no audio play. you can record audio without change microphone pos and speaker pos and volume and compare the files with headphones in the foobar 2000 ABX test. if you then choose 8 times correct version then you can sure there is diffrence. or upload soundrecord, then all can test if they can hear a diffrence
I will make something for listening with my low quality microphone or is it a better idea to record with OC18 from Austrian Audio? I would also like to test the linear supply, but I am afraid to not burn it
