bennybbbx
in short d3v have more low bass as the JBL 104 and esi unik 05+. the yamaha HS5 many youtuber have in their studio which is called have low Bass have most bass only below 40 hz . above 40 hz it have really low bass . position of speaker and microphone 75 cm to hearing position was same. i have it on desktop with a 25 cm stand
thats right speaker. diffrence happen because i can not place my desktop symmetric in room because L geometry room. treating i have ~18 qm but help not with measure results i try much diffrent placings. only decay time is shorter
now the 6.5 inch speakers in compare. only lower as 45 hz the 6.5 inch speaker rules, but they produce mud in lower mids 100-400 hz hear snare drum in audio testpiece. really great for a 3.5 inch speaker that produce no port noise. I think low bass of d3v really great, very often below 42 hz is not play important. kick drums are in range 50-70 hz so you get full punch with d3v and no nasty boom boy sound. sure the desktop have influence to this, but because d3v sound more better the problem is not desktop. speaker developers should not only test their speakers in a good room. they should do burst tests or at least test in not good rooms
right speakers
the d3v with the passive membrane sound much better as all i have even if it have high level in 100-400 hz range. i like that currently i do not reduce it because clarity also with no EQ i think great and sound warmer. on headphones i like not reduce 100-400 hz because give strange feeling in ears, but on speaker in the past was important to get clarity.
in this thread you find more explain how the audio records are done, somw burst measure https://www.audiosciencereview.com/forum/index.php?threads/adam-audio-d3v-specs-price.57557/page-6
right speakers
