Svs wireless
for the price of Svs wireless, i can add a little more and buy a DAC with balanced outputs. but I don't want to go that routeSvs wireless
how many prongs are on the 3e A5 power cord? I've done a little googling and others have had some ground loop issues with this amp. Can you borrow another amp to try?for the price of Svs wireless, i can add a little more and buy a DAC with balanced outputs. but I don't want to go that route
2 prongs.how many prongs are on the 3e A5 power cord? I've done a little googling and others have had some ground loop issues with this amp. Can you borrow another amp to try?
hmm, okay but like i mentioned above, not going to spend money to solve an issue i didn't notice when i hooked up the Ultra, and an issue I workaround easily with connecting the SU1 DAC i already have on optical out, and it sounds great. I was looking forward of using the Ultra's DAC ..but no big deal. my next upgrade would be probably a DAC with balanced inputs - i think that would actually give me a real upgrade over "issue solving" with more equipment.I know these devices were mentioned already but I figured I would share my very positive experience with one of these type devices.. specifically the SVS model. When going from a dac/preamp with a proper dual output & then using the line level device I do need to up the volume on my SVS sub a couple of db louder to get comparable output levels in bass.
Oh yeah, I've had or still have a SVS wireless device. I very much prefer the line level device. The wireless device has extra power cords, rca cords, the one I purchased was a pain in my opinion & placements couldn't be obstructed from each other. And I hate extra cords/cables.
I'm assuming you mean a dac with balanced outputs. Btw are you connecting to the dac with toslink or coax? I would think that toslink (optical) would break the ground loop.hmm, okay but like i mentioned above, not going to spend money to solve an issue i didn't notice when i hooked up the Ultra, and an issue I workaround easily with connecting the SU1 DAC i already have on optical out, and it sounds great. I was looking forward of using the Ultra's DAC ..but no big deal. my next upgrade would be probably a DAC with balanced inputs - i think that would actually give me a real upgrade over "issue solving" with more equipment.
yes, balanced outputs. i'm connecting over toslink, and just now i connected the SU1 over USB and it sounds great as well (yes, the sub works now with USB output)I'm assuming you mean a dac with balanced outputs. Btw are you connecting to the dac with toslink or coax? I would think that toslink (optical) would break the ground loop.
Wayne
I forgot that you are connecting to a computer via USB, that might be the source of your ground loop. As an experiment you could try to hook everything up as intended and disconnect the usb cable to see if the ground loop goes away.yes, balanced outputs. i'm connecting over toslink, and just now i connected the SU1 over USB and it sounds great as well (yes, the sub works now with USB output)
my laptop isn't connected over USB - it's connected over Toslink input from SMSL PO100 DDC. but i'll give that a tryI forgot that you are connecting to a computer via USB, that might be the source of your ground loop. As an experiment you could try to hook everything up as intended and disconnect the usb cable to see if the ground loop goes away.
The USB connection the OP is referring to is the Wiim Ultra's output. The Ultra can output high-passed signal for main speakers from its analog, coaxial, toslink or USB port. It has no USB input. The OP can use any of these with their existing DAC, the toslink at least solves the ground loop issues.I forgot that you are connecting to a computer via USB, that might be the source of your ground loop. As an experiment you could try to hook everything up as intended and disconnect the usb cable to see if the ground loop goes away.
yes, that's one of the first reasons i bought the WiiM Pro and now upgraded to the Ultra. I'm using external Behringer ECM mic connected to USB "Mic Mate" to XLR adapter and to the phone as an external mic. works good, still playing with it - don't like the low frequencies being lowered so much (for example) when sub calibration is enabled.@anonyless I suggest sticking with your current setup so long as the ground loop buzz is gone, a DAC upgrade shouldn't make any audible improvement. Have you tried playing with room equalization?
Not necessarily, usually the voltage gain is lower for balanced inputs vs single ended inputs so the volume would be the same. Does your system not get loud enough currently?DAC with balanced outputs won't give me higher volume input into the A5 amp
I wasn't happy with the Wiim room correction when I tried it, but you have taken the extra step of using an external mic! Do you have the ability to measure with REW, create filters using a target curve, and then apply the filters to the Wiim PEQ manually?still playing with it - don't like the low frequencies being lowered so much (for example) when sub calibration is enabled
it does. i'm just curious about using the balanced inputs of the A5 amp.Not necessarily, usually the voltage gain is lower for balanced inputs vs single ended inputs so the volume would be the same. Does your system not get loud enough currently?
i managed to "install" REW on my Fedora (Linux) laptop , forcing it into using Pulseaudio and using the microphone. but it's a bit too "audio technical" for me right now. i might give it another try at one point.I wasn't happy with the Wiim room correction when I tried it, but you have taken the extra step of using an external mic! Do you have the ability to measure with REW, create filters using a target curve, and then apply the filters to the Wiim PEQ manually?
