Active Standmounts
Yeah there are way better deals, like Buchardt A500 if you want active. Or you could probably afford JTRs on that budget. The Genelecs won't stand a chance.
I own both JTR 212RTs and 8351bs. The 8351bs sound noticeably better to my ears(non-blind). As for A500 vs 8351b, the measurements show the Genelec to be the better speaker, but at nearly twice the price, I think I would argue the A500 as the better value. That will be true of almost any speakers at those price points, though.
The JTRs do the blow the Genelecs out of the water though in terms of dynamics, and I can listen to them at a louder volume(without pain) than I can with the Genelecs.
Resale value is an interesting point. I honestly have no idea how they'll hold up. FWIW my last 2 speaker purchases (Revel M106 and JBL 708p) have been on the used market. $900 and $2200, respectively, so take that FWIW. I've also been shopping for used Salon2s for a year or so, and I've seen them as low as $9,000 on the used market.
That's interesting that you say the Genelecs are noticeably better-sounding than the JTRs. How would you describe the difference? What are the JTRs missing?
I am a current owner of a pair of S3000 Pros and also think they're difficult to beat for the money (which is more than the equivalent of $500 in the UK sadly).
You didn't answer my question about what DSP use you were referring to. I asked as you seem to be somewhat confusing 'room correction' and crossover/speaker response corrections in your posts. Your Swans would benefit from a miniDSP for EQ in the bass region to account for room mode effects despite utilising DSP in its design.
What I meant was passives will need as much help, be it room correction or a good dac oe anything to minimize the gap between good active speakers since actives have an active crossover that most passives will never have. The DSP in actives are doing all the dirty work, correcting tonality, smoothing bumps and dips that naturally occur with the speaker design. Yeah, room correction will certainly improve the active further but this applies to all speakers.
Like I said, the S3000Pros are great for the money and Ive never come across any speaker amp combo that could beat it for the same price. Its just that the higher end Swans are so much better, but rightly so for its price.
Emotiva B1+ and SMSL AD18?
In my opinion, no... Ive had the B1s in my listening room before (I have not heard the AD18 before but own a DA9 fwiw) and they are not as good sounding as the S3000Pro. The S3000Pro is just a more complete sounding package, extended lows, more neutral overall (in monitor mode) and can get into party mode easily which a press of the button. I have to go to separates which cost double (ie Wharfedale Diamond 12.2 with the DA9 and a dac or the Cambridge AXR100) to better the s3000pro in most areas. I still dont get that deep bass of the S3000Pro though.
They measure way better that the 1280db, no doubts about that and from all the charts Ive seen online (cant compare apples to apples as Amir have not tested the s3000pro), as long as you have it in monitor mode, the s3000pro looks flatter than Amir's measurements of the B1s. Thats the active dsp/crossover doing its magic again right there.
So the B1+ doesn't have a lot of bass. Both speakers need subs anyway.
You dont really need a sub for the s3000pro. A claimed 37hz anechoic isnt something to be sniffed at. And the B1 is crying for a sub. And there is a matter of clarity, soundstage, imaging, instrument separation that charts dont show. The s3000pro is superior in those areas. And its more neutral when you want it to. S3000pro owners or people that have actually heard it in a well setup room (not on desktops) will tell you the same. Anyway, I dont own the s3000pro anymore and that is all I can say for the speaker. Lookin to up my active speaker game now and Swans, once again, look unbeatable in its prce range.
Very very different sounding speakers. The Genelecs have a better balance(imo) between envelopment and pinpoint imaging. They don't image quite as sharply as the JTRs, but they get maybe 80% of the way there, while giving me a much greater sense of envelopment. There's also just nothing at all I can pick out tonally that sounds wrong with the 8351s. Not that I can really pick out anything wrong with the 212s, but side by side they sound a little less balanced. The 212s do have advantages of their own. I can listen to them much louder without pain; whether that's due to less distortion/compression or just narrower treble dispersion, I'm not sure. I think both represent great value, and I'd favor one over the other depending on use case. My main use case these days is music listening at ~83-92dBC(average), so the 8351bs get more playtime. I'd still take the JTRs for a custom home theater meant for reference level playback.
I would rather have passive speakers with a 2x4 HD to manage room modes in the bass region than have active speakers and an uneven bass response. Personally I think the biggest benefits of active speakers come from aspect other than using DSP to make minor adjustments to the output.
I'm currently have S3000 Pros set up in my lounge and used with a subwoofer. I similarly use a subwoofer with my Meadowlark Shearwater floorstanding speakers that have a very similar bass extension. I think it is a mistake to simply look at bass extension to conclude whether a subwoofer can be used beneficially or not - I think you have to try very hard to come up with a stereo speaker setup that wouldn't benefit from a subwoofer (or more). I'm talking optimally placed subwoofer(s) and good integration, including high-pass filtering the main speakers.
To each their own. You prefer a sub for the s3000pro, I dont feel the need for it. You prefer using passives with the 2x4 over active crossovers and dsp on actives, I dont. We will leave it at that. What I said stands, you could get away without a sub on the s3000pro, you cant with the b1.
KEF has a sizable presence in asia, maybe look at prices of r3, ls50 meta, ls50 meta wiresless II
2x4 HD not 2x4 for what it's worth - I would not recommend the latter.
I'm just sharing thoughts on the subject :). You also raised the concept of room response correction yourself earlier but it wasn't clear if you had any experience with this? Trying out both this and a well integrated subwoofer are both things I'd encourage you to do if you have the opportunity some time. The results may surprise you :).
I heard the Wireless 2 next to the M5A, the Swans distributor here had that set up because they were so confident of the M5A and M3A MKII. I felt the same, and this is subjective, hands down the M5A. No contest. Im an english speaker kind of guy but it wasnt even close. The W2 has way better connectivity though and that might sway some people. Im very interested in the R3 and R7 but I have not heard both in person. I will see if I can audition those.
I've no experience with that brand so I can't comment much. A cursory search for these swans also shows that it seemly has a fairly flat FR and better bass extension than the LS50M/II, so if they are otherwise good I would expect them to probably sound more full and perhaps "better" compared to LS50 when compared against each other. Just remember showrooms do not represent how they will sound or respond in your space and undoubtedly the comparison was not level matched and perhaps not conducted at various listening positions/axes. If you don't plan to have a subwoofer it could very well be the better choice, but the KEF LS50 could likely be superior with a subwoofer. I also imagine the KEF would be easier to EQ and have lower distortion, and also better resale/2nd hand value.
I don't agree that you need to spend 2-3x on passive speakers. In other words, I don't agree that active speakers can cost 1/2 to 1/3 the price of passive speakers and get the same sound. If this is the basis for your thesis, I'd suggest a re-evaluation.
I suggest you look at the reviews/tests on this site along more controversial stuff like GR Research to see how utter rubbish many so called high end speakers perform.
The reason many passive speaker designs behave so badly is because of the sink hole of trying to solve transducer frequency response with passive crossover networks. I can't think of a more out dated and hopelessly pitiful corner of electronics than this. Caps, spools of solid core enabled wire, and resistors. If you pay more money you get higher quality caps, resistors and spools of enameled wire.
We want our TV calibrated with the best possible picture and low compression rates, but B&W can ship a production speaker that will make your ears bleed out of your eye balls and audiophile media brags about its treble clarity. No brain. No headache.
Active speakers by design can be linearized much cheaper and more consistently than a passive design unless the passive speaker makes massive compromises. This is a fact of fundamental transducer design.
The thing is, audiophile culture doesn't want dead neutral speakers.They want to listen to their amplifiers, vibration isolators, and high end power cables. Active speakers as a market segment could be that much better but the bar has been set pretty low by the passive speaker industry.
The shit I see on 4000 bucks speakers when GR Research tears them apart makes sometimes make me wanna puke. Imagine seeing such capacitors used after splurging a few grand on speakers. They spend all their money to make the outsides look so high end but neglect the most important parts.
The mastering studio are dominate by the hifi speakers.
The audiophiles blabla... When i visit Gearslutz,The so-called pro go beyond the audiophile joke.
The passiv industry jbl lsr 32/ 6332...
