fpitas
Never heard of schlager before this. The More You Know...Crazy I can handle. If you want me to gag, Jazz, country or schlager will do the trick.
That's German "modern" folk. I cannot bear most of it.Never heard of schlager before this. The More You Know...
Possibly from ones not made by Genelec?I have a friend who does semi-pro mastering for voice actors and still uses genelecs 1022A from 1990 without problem. I'm not sure where the myth of fragile active speakers comes from.
Well, possibly Behringer is to blame:Possibly from ones not made by Genelec?
www.audiosciencereview.com
I'd say buy things that are long on the market like Genelec and Neumann(K+H), exhibit caution with othersPossibly from ones not made by Genelec?
For steel, cryogenic treatment actually results in an increase in resistance, more than doubling in some cases. Cryogenic treatment was developed as a way to increase hardness and wear resistance in tool metals. This is just another example of audiophile snake-oil merchants latching onto something they don’t understand because they know the gullible fools they sell to will be equally clueless.
Sounds like Polka.oooh, there are many superb Schlagers, e.g.it's actually sad that German's culture is almost totally dead
the instrumental parts of a Schlager are not really inspiring, quite often it's just a sort of monotone background-sound. A good one is mostly about good vocals and excellent lyrics: poetry, philosophy, story telling ... and often hard to translate between cultures.Sounds like Polka.
For a resistance that low, I would want a 4-wire Kelvin connected fixture. Individual force and sense leads separately connected to the DUT (Device Under Test) are mandatory for an accurate measurement of that low a resistance.View attachment 318259
I find the bar locking/measuring system curious. Could the resistive measurement in milliohms through two copper rods have given incorrect values since they were different materials/conductivities? It's just curiosity.
Behringer is to blame for a lot of things.Well, possibly Behringer is to blame:
Behringer B2031A Measurement (broken sample?)
Hey you all. Just finished measuring the Behringer B2031A. This is the spin: Even in-room measurements without NFS scan showed the same massive trough. Before I contact them, is there some config option that could cause this? I left all the filters at 0 (as shipped). Near-field tweeter...www.audiosciencereview.com
Also for your late reply?Behringer is to blame for a lot of things.
Better late than never? Behringer has been bad about infant mortality. My first DEQ2496 was a basket case from the factory.Also for your late reply?![]()
that's because the cryo treatment took longer than expected ..Also for your late reply?![]()
You can't rush quality!that's because the cryo treatment took longer than expected ..
nice find and quite a carbon-copy by Mr Bing. The only change was to eliminate the word 'greek'
Mine crapped out soon after I got it too. It sits unused in the garage. It appears to be well made inside, and I'm at a loss as to what's wrong with it. Nothing looks burned. Power supply appears to be working normally.Better late than never? Behringer has been bad about infant mortality. My first DEQ2496 was a basket case from the factory.
The only Behringer thing I ever owned, I murdered myself by trying to hack a useless new power supply in itMine crapped out soon after I got it too. It sits unused in the garage. It appears to be well made inside, and I'm at a loss as to what's wrong with it. Nothing looks burned. Power supply appears to be working normally.
