prestigetone
- Joined
- Feb 12, 2021
- Messages
- 405
- Likes
- 492
ExactlyNo agument with that. But why have an external dac when it is not needed? If using Ronn via ethernet you can have a physical volume control.
It is always needed if you use DSP as you can't feed a power amp a digital signal.
Probably which is before a digital processing device, because such an equipment uses digital data and if it have analogue input, than an ADC will follow that. So in this case we have two unnecessary conversion (a DAC and an ADC) if we using digital source and analogue input on a DSP equipped unit.
That extra conversion point kind of nullifies your choice of external DAC.
I see what you mean.So is it needed or not? I was referring to your statement "Why wasting money on a unnecessary DAC"
If you go from a digital source to analog using a DAC only to have the analog signal converted back to digital (ADC) because the monitor does the crossover etc using DSP, this DA conversion can be skipped hence I do think this DAC unnecessary.
The output of the DSP (digital by design) has to be converted to analog by the DAC inside the monitor. These DAC's are needed of course.
If you are using a digital source and a unit with DSP crossover, this DSP equipped unit expects digital data, so a DAC before this DSP equipped device is unnecessary. Unnecessary, because the DSP equipped unit still needs digital data and not analogue, but to fed analogue signal to the DSP equipped unit, it needs to have an ADC too. So after all, one DAC and one ADC is unnecessary in this chain if we can send digital data directly to the DSP equipped unit, which of course have it's own DAC before the amplification.They're not "unnecessary", they are needed for DSP and digital crossovers. I could say that we have "unnecessary loss" in an analog crossover, but it's a consequence of needing a crossover. The loss of the DSP is likely less than an analog crossover, but no one is complaining about that.
Try to stop thinking of it as a DAC, but rather as a digital crossover.
If you are using a digital source and a unit with DSP crossover, this DSP equipped unit expects digital data, so a DAC before this DSP equipped device is unnecessary. Unnecessary, because the DSP equipped unit still needs digital data and not analogue., but to fed analogue signal to the DSP equipped unit, it needs to have an ADC too. So after all, one DAC and one ADC is unnecessary in this chain if we can send digital data directly to the DSP equipped unit, which of course have it's own DAC before the amplification.
Not necessarily the audibility of the additional DAC-ADC cycle, but this concept doesn't make much sense.
For some it's perfectly fine, for some others maybe not. The reasons may vary.This is all great in theory, but in practice most will have a system setup where the most viable option is to send analog data to the speakers, which is perfectly fine.
Clear, thank you! Will also take a look at the miniDSP flex.Yes, you can use the remote control of the Hypex Fusionamp (FA). This way, all you need is to connect the sources to the Master FA and if the number and type of the inputs on the FA are enough for you then you are good.
Another good digital output "preamp" is the miniDSP Flex digital out version, which is cheaper than the SHD or SHD Studio.
This has been an excellent discussion, thank you very much @sigbergaudio, @Purité Audio and others for your comments. Seems in conclusion if you are able to use dig inputs, do so. If you are not, there is no audible difference (though some have mentioned a subjective difference).
My thinking at this point to sooth my audiophile nervosa (it’s a real disease, look it up, kidding, but it should be) would be to use the dig input for 2ch system, then for 5.1, 7.1, etc use the analog inputs. Unless there is a theater processor out there with multichannel dig outputs, certainly doesn’t exist (yet) as far as I know. But for 2ch, the miniDSP SHD Studio definitely seems to fit the use case for dig out. But definitely not cheap. Any other dig volume control devices out there? Also, can’t you just control the volume of the Hypex modules with the remote? So maybe all you need is dig bitstream to Hypex, then volume control with Hypex, and you are good to go, or have I misunderstood?
Are there any audible sonic (bandwidth) differences between optical, dig coax, or AES? I researched a bit on the interweb and found contradictory statements, not sure what is accurate.
LOL … I ain’t a bat, so should be good. Thanks!No. Optical has lower bandwidth, but only the bats are worried.
