Thank You
I was in a group buy for M2 and i sat for hours if i should go for M2.
Have listend for them a couple of times in both large and small rooms, mine is only 25m2 and ~3,6met wide.
And in smaller room the wide dispersion made it sound, strange and with little focus.
My room it self acts as a giant panel absorber and with a RT60 below 20ms.
But there is still reflective surfaces so i did not dare.
And i had read about AVS forum member Notnyt who built with Prs wave guide and 2453SL.
So i talked with him and decided to do the same, i can still use M2 wave guide if i want to.
Before this setup i used 2226 in the same kind of boxes, it also worked Really good.
Do not see any point of have ported system but have a crossover several octaves above the tuning.
You have not thought of M2 as MTM ?
