ThELiZ
This is similar to what happened with me when I had my 7.2.4 setup. Certain groups were not selected to be support groups.
At first I just thought Dirac chose not to use them as it ‘maybe’ decided they weren’t helpful as a support group. But I doubt this is the case with your subwoofer.
It just so happened, though, that this group was my rear surrounds… The ones that weren’t active when I was playing content.
I’d be interested if you played some sub content with this setup and see if anything is happening with that sub.
Also, could you please do me a favour and check the ‘info’ button on the remote when you are playing content and see if it shows all channels as active? That would confirm if it’s just a ‘me’ thing where I can’t get my rear surrounds working.
As for your issue with your sub group… For reference, when I split one of my subwoofers out from the initial group, I was not able to select a curve for that subwoofer or select any speakers to support it… According to Dirac, this is normal. Confirmed by @slaweks post.
