scotchrocks
- Joined
- Jan 3, 2024
- Messages
- 58
- Likes
- 131
ART still doesn't have any kind of loudness feature? Even before ART I preferrred room correction results from Dirac compared to Audyssey, but since my use case is 99% low to moderate volume listening, I keep going back to Audyssey just because of Dynamic EQ... :/
I've been using the Dirac Harman target curves with ISO 226 loudness correction provided by @popej here: https://www.audiosciencereview.com/forum/index.php?threads/targets-for-dirac-live.53435/post-2361722This is true, but if you know around what volume you typically listen at, you can bake an ISO226 curve into the target curve you give to Dirac. I don’t have Dirac but I think that’s what owners are doing.
This gives you predefined curves for various combinations of Harman slopes and loudness reference levels. With the D+M receivers, you can load 3 filters, so you can save different target curves based on listening levels/situations (e.g. music, low volume TV/movies, high volume TV/movies). It would be great if Dirac made updates for this to work dynamically based on a specified reference level, but at least this provides a workaround that gives full control over how much loudness compensation is preferred.
I've been using the target-10dB-h8 primarily, which sounds good to me for most material and listening levels.
