ban25
- Joined
- Nov 5, 2022
- Messages
- 1,327
- Likes
- 1,422
I wouldn't do it. In that case your sub has to convert the input signal back to digital, apply DSP, and go back through its own DAC before playing the signal. All those steps add several ms of latency, which Dirac then has to counter by delaying all other speakers in your system in order to properly time-align. That pushes your video further out of sync with the audio, all for no actual benefit since Dirac is already more capable of EQ'ing the bass region than whatever your sub has built-in.Sorry, I have a possibly silly question. One major difference between StormAudio and D&M regarding ART is that StormAudio allows detailed PEQ adjustments before using ART. If I'm using a subwoofer that supports PEQ adjustments via its app—such as SVS, Perlisten, MK Sound, etc.—can I achieve the same result?
In other words, can I use REW together with the subwoofer's app to adjust the PEQ and flatten the low-frequency response curve before running Dirac?
As a rule, I avoid subwoofers or other active speakers with on-board DSP, especially if it cannot be defeated.
