It already IS implemented in all StormAudio processors and every measurement I found showed incredible good results! This doesn't look like struggle at all.I bet they are struggling to adapt it to home cinemas and I doubt they will ever be able to come up with a robust solution.
You must know something Gene of Audioholics don't since he couldn't get his Storm working with ART and publish test results since longer than a year now:It already IS implemented in all StormAudio processors and every measurement I found showed incredible good results! This doesn't look like struggle at all.
The complexity of these calculations is huge - I was really surprised to see the results. But there are plenty of installations out there (storm audio processors) and they work (like Trinnovs system also works).
I bet all these amps with 4 sub outputs are made with ART in mind. No idea why they struggle to implement - an official statement would be gold.
Denon/Marantz are fine. The same SHARC ADSP-21593 chip runs across most of the x800 lineup and is even in the flagship A1H!Good point. Considering the absolute phenomenal growth of AI/deep learning/deep, neural networking or whatever you want to call it, in the last 1 to 2 years, I would think that this would help with ART implementation immensely . But now that makes me worried that the promised implementation into the current model lineup of Denon and Moran's equipment won't end up happening because the processors in them won't be powerful enough to do the job
Gene's issue there seems to have something to do with his infrasonic bass response (which I don't think ART even attempts to address with a HPF at 20Hz) and his active speaker setup (which probably introduces additional latency issues that a more common passive system wouldn't have). However, even if some people have ART working with Trinnov/Storm, those systems have way more computation resources on hand than any traditional AVR I'm aware of and have probably had tons of tinkering done by the owner, the manufacturer, and/or Dirac themselves. Getting it working on an AVR with limited compute and without requiring a lot of support time is certainly not trivial, if it's even feasible in the first place.You must know something Gene of Audioholics don't since he couldn't get his Storm working with ART and publish test results since longer than a year now:
When will Audioholics share their thoughts on Dirac ART?
Ya'll mentioned months ago that you were trying out StormAudio units with Dirac ART. When do we get to hear your impressions?forums.audioholics.com
It seems that Gene problems are related to the infrasonic band of his particular system, not correctly managed by ART.You must know something Gene of Audioholics don't since he couldn't get his Storm working with ART and publish test results since longer than a year now:
Then again, ART also works with the Monoprice HTP-1 and it has over 6 years old technology/DSP.However, even if some people have ART working with Trinnov/Storm, those systems have way more computation resources on hand than any traditional AVR I'm aware of
Does it? I see no mention of ART on Monoprice's listing nor do I see mention of the Monoprice on Dirac asides from the usual DLRC/DLBC licenses. Also, do we have any info on what compute resources the HTP-1 has? Regardless of age, it can easily outclass an AVR with a hardware DSP chip depending on what its running.Then again, ART also works with the Monoprice HTP-1 and it has over 6 years old technology/DSP.
Yes it does, I actually have it running (alpha test version). It's not publicly available and I'm not sure if it ever will be.Does it? I see no mention of ART on Monoprice's listing nor do I see mention of the Monoprice on Dirac asides from the usual DLRC/DLBC licenses. Also, do we have any info on what compute resources the HTP-1 has? Regardless of age, it can easily outclass an AVR with a hardware DSP chip depending on what its running.
My best guess is that the core issue isn't simply about sending a MIMO polarity-inverted signal to cancel a reflection before it reaches the wall. In theory, any speaker in the system could contribute to that with precise timing. The challenge is that the counteracting signal doesn't just eliminate the reflection and vanish - it continues to bounce back and forth in the room. This creates extra energy that wasn’t part of the original audio track. I had similar experience while working on virtual bass array filters in the past. I suspect that’s why Trinnov relies on multiple sets of subwoofers, strategically placed on non-adjacent walls for MIMO bass arrays.It seems that Gene problems are related to the infrasonic band of his particular system, not correctly managed by ART.
Bug also confirmed by another Audioholics article, where on the other hand they show a correction of Dirac ART as per textbook.
Before:
After:
Actually I have not yet seen other technologies achieve these results via software. It is necessary to mathematically model the acoustic response of the room and apply MIMO processing in order to do so. A simple FDW with an inversion filter is not enough.
Reports by StormAudio ART users and reviewers are consistently positive....It worked in cars where they know the exact shape of the environment, listening position and reflection coefficients. I bet they are struggling to adapt it to home cinemas and I doubt they will ever be able to come up with a robust solution.
Gene reported that his main issues related to using full range speakers and using them as corrective speakers...It seems that Gene problems are related to the infrasonic band of his particular system, not correctly managed by ART.
Why?
No, you can do a basic setup with a single point, or a 3 point measurement....I know Dirac requires measuring with specific layouts, at minimum 9 points (cube). If the position of the measuring points is known, I suppose it is possible to create a mathematical model of room reflections with machine learning algorithms and define speaker response whose sum combines to the desired IR at the MLP, regardless of the geometric and acoustic unknowns of the environment.
I understand that Dirac intelligently uses stochastic to calculate filters instead of deterministic, in order to make the calculation possible on normal PCs.
I imagine this introduces considerable complexity given the amount of variables involved, so if the algorithm does not appropriately define the limits within which to attempt the stochastic simulation, derived from the calculated acoustic model of the room, the result will be anything but good.
Personally, I am convinced that AI is crucial to these tasks and the fact that DIRAC is pointing in this direction, summed to the concept of active wave forming, is precisely what makes me believe in the validity and innovation of their approach.
I hope they manage to fine-tune ART in order to exploit total potential.
