Correct, Marantz “was” adding gain post Dirac. Dirac has shut that down now and I understand why. Now on the Tide16 it looks like the trim adjustments are made pre Dirac. Monolith HTP-1 also does this and then these trims are included in the Dirac calculation (I believe). On the Tide16 If you are able to adjust Center trim real time by movie (let’s say u boost Center by 5db for some movies) and you have other channels supporting the Center how do the anti phase signals know to fire louder given the +5db change you made to the Center, given this is pre Dirac?
Sorry to clarify are you saying you can adjust Center trim real time per any movie scene or are you saying you can adjust Center trim once and then Dirac uses the new trim level in its calculation?
On the Tide you can adjust the level of the center channel
up to plus or minus 10dB using a level control on the remote, or using the Console app on your computer, in real time, while you are watching the show. I just used it, watching an old TV show encoded Dolby surround, where the original media (a DVD) has the dialog in the center and too low. I adjusted the center until the dialog was sufficiently prominent. Checking the console, I raised it
1.5 dB (the console is an application that accesses information and features for the Tide in great detail.) You can raise or lower the level as much as you want while watching, like a volume control.
It does not have any audible effect on the overall ART room correction. I don't know why, I have no technical expertise about ART under the hood, just practical use. I do know that it is adjusting the
input level of the center channel
post dts/Dolby decoding, but
before Dirac processing, and it is only the level of the center channel input that is being raised (or lowered), not the level of any support or other signals being redirected to the center speaker,
it is processed by the Dirac suite at the trim or gain level adjustment, and the designated support speakers (for the center) are providing support signals using the level that you set when making any adjustment.
I only use this feature for TV/cinema where the center channel is carrying the dialog, and only to the extent necessary. It is a precise control. A short tap of the up or down control is
.5 dB. I was surprised to find out that small changes can make a big difference.
I'll say it again, the Dirac suite is integral to the design of the TIde. It is not an "add on" feature. I can't compare to any other brand, but my experience is that Dirac processing on the Tide is superb.
