Thanks that’s what I have done in my custom center curve but still find increasing the trim level +3db helps. Marantz is taking away the trim level functionality so just trying to find another way to simulate it.
PS: Doing it in dirac is better, channel level adjust works as a quick fix once in a while with problematic mixes. I SHUT OFF ALL UPDATES 3DAYS Ago, it updated anyway yesterday, boom channel level adjust is gone. I likes it for the occasional hard to hear dialog movies,now I just make a extra curve for dialog.
From Denon and Marantz
Disabling Channel Level Adjust when Dirac Live ART is active
With the firmware update to be released in June 2026, the operational specifications of Channel Level Adjust while the Dirac Live Active Room Treatment (ART) is active have been changed.
In this update, Channel Level Adjust will be disabled when using Dirac Live ART is active in order to maximize the performance of ART.
Operation when Dirac Live ART is active
When using Dirac Live ART, “Channel Level Adjust” in the Option menu is disabled and hidden.
When using Dirac Live ART and Channel Level Adjust together before the firmware update
After the update, the values of Channel Level Adjust that were set manually before the update will no longer be applied.
Instead, the channel level balance based on Dirac Live measurement is automatically applied.
Enabling Channel Level Adjust
You can use Channel Level Adjust again by either turning off Dirac Live or selecting a filter to which Dirac Live Room Correction, Bass Management, or Bass Control has been applied.
