Same same, pre eq looks barely better. I’d do a preset a vs b good enough comparison and pick the one that sounds better to you.
Decay and waterfall with the combined result- do you have that to ?Same same, pre eq looks barely better. I’d do a preset a vs b good enough comparison and pick the one that sounds better to you.
Front left subs not pr-equed in SVSDecay and waterfall with the combined result- do you have that to ?
If one are not going nuts with pre-correction ART should be able to handle it.
Thank YouFront left subs not pr-equed in SVS
Same channel, same Art settings, same TC 2 subs pre-equed in SVS
Front left + subs Art Waterfall same channel NOT pre-equed in SVS . (Note: usually I prefer to measure L+R+subs for waterfall but I didn't do it this time)
FL+subs pre-equed +Art: (ringing at 60Hz is the refrigerator don't worry!)
My listening tests continue. All placebo effect???????? Can't say for now! Maybe...
There is a noticeable difference between the two approaches. In film soundtracks, the musical instruments are more prominent and detailed, the sound stage of the music goes further away the front wall (deeper) the surround sound is slightly more pronounced and expansive, and the bass is stronger. I’m talking about nuances that are fairly easy to pick up on, but it’s not a drastic change. I haven’t listened to any music in stereo yet. I’m still surprised to hear such subtle differences when analysing the various criteria in REW.
I obviously know the response of my subwoofers inside out. Before Dirac, I had integrated my subwoofers with a miniDsp 2x4hd and then manually mixed them at the crossover with the satellites in my AV receiver using 10 filters per channel. I got the best results if I reversed the polarity of one subwoofer. We know that neither DLBC nor Art do this. But my impression is that by first equalising the subwoofers in SVS, it’s as if Art were reversing something like the polarity of one of the subwoofers in the filters between 20Hz and 60Hz. Perhaps I’m just letting my imagination and my OCD get the better of me.
Don't no anything about Automatic for SVS peq.BTW did you use "normal" SVS EQ or the new Auto EQ?
Right - just did some reading on SVS Auto EQ and works only with new R/Evolution series. So for the older ones, only manual PQ.Don't no anything about Automatic for SVS peq.
In the app I can set manually 3 filters for each sub, selecting Q, gain and FR for each filter. I choose to always cut gain. When I will have time, I may try to reduce filter to one or 2 filters only with a larger Q (< 1).
Art is doing amazing things anyway.
There is absolutely no reason why ART would, in general be inferior to DLBC. It is supposed to be same or better in FQ response and ways better in decay control.With an ART calibration using Harman 10db curve (which I used extensively with DLBC with no issues) it struggles to hit the curve below 50hz
When listening to movies there is a sound of something being overdriven on bass peaks in the soundtrack
I'm running 4 SVS PB3000 in corners in a single ART group supported by Centre and Mains at -18, 50Hzx
Digging into it with REW the overall picture shows the same effect as a classic crossover, in this case at 48Hz
Note the support is flat from 45-130Hz despite FSL at 50Hz
The individual subs however show wide variation in filters applied which makes me think I'm losing significant headroom
View attachment 534753View attachment 534754View attachment 534755View attachment 534756View attachment 534757
check the filters being applied to the subwoofers if one is being used more than the others, it also could be the speakers reaching their limits. 4 subwoofers are enough to support each other without much contribution from other speakers below 80Hz.With an ART calibration using Harman 10db curve (which I used extensively with DLBC with no issues) it struggles to hit the curve below 50hz
Some questionsWith an ART calibration using Harman 10db curve (which I used extensively with DLBC with no issues) it struggles to hit the curve below 50hz
See my graphs postedWhat does each subs individual response look like? I’d prefer to see the Dirac measurement screen shots of their measured response but whatever image works for you.earlier
1 width 4mSome questions
1#
Is any wall length or ceiling height 2 or 4 meters ?
2#
Room measurements and where is MLP - pic from REW would be great.
3#
What is support range within the subs group, and is the same setting used to support LCR ?
4#
When the overloading occurs, is it when listening to music or movies ?
And what lvl are you playing ?
And for tips - change LFE sub to another might help.
Have one group for each sub might also help
Also, to move the subs might also help
And lastly, my setup can play Crazy loud with Dirac/DLBC but i have loosed a bit of the top end.
To widen the measurement area, using 13 points helped a bit![]()
You can see the effect of filters in the with/without graphs.check the filters being applied to the subwoofers if one is being used more than the others, it also could be the speakers reaching their limits. 4 subwoofers are enough to support each other without much contribution from other speakers below 80Hz.
See graphs already postedWhat does each subs individual response look like? I’d prefer to see the Dirac measurement screen shots of their measured response but whatever image works for you.
Thanks for your inputThere is absolutely no reason why ART would, in general be inferior to DLBC. It is supposed to be same or better in FQ response and ways better in decay control.
While you have subs that are pretty good, +10dB curve is a challenge (with +12dB being the max). What are your sub levels at AVR level and gain on the subs? I would doubt that they tap out even in large room but worth to ask.
It is normal that ART uses different subs with different filters, so that is not indication of losing headroom. Figuring out the ART filters is a bit complex with REW, but you can pull the ART screen that will show you what is the response for each channel and will be easier to comprehend as contribution from each channel will be overlaid.
Not sure why ART is running your LCR support this loud. I have LCR to F3 of 30hz, and also set to 50-120hz, but they start kicking in only at around 80-100hz.
1 width 4m
2 8x4x2.8 MLP centre 3.7m from screen
3 Yes
4 I only listen to movies. High level transient bass sometimes uses the effect
