Hello,
i've been using DIRAC ART with a Storm audio ISP since Jan 2026. I came from an Anthem AVM90 with ARC Genesis.
DIRAC ART has both impressed me with the bass decay and clarity, and at the same time frustrated me with the weird and unpredictable bass impact performance with HT and multichannel concerts content.
In stereo, the bass decay, texture and transient clarity is very very good. However, this strength does not translate to HT and multichannel concert content. Some HT content have very good bass transients and impact, similar to stereo, yet other HT content the bass sounds smeared, sluggish and vague. This was absolutely confounding to me.
After a lot of digging and troubleshooting, measurements, i think i have finally figure out the explanation. The hint was the 'known issues' in the DIRAC ART release notes.
This has been mentioned many times in this thread, but so far i don't think anyone really understand what it means and how it impacts the performance of DIRAC ART with actual bass content.
First, let me share measurements of what this 5ms LFE delay means. It means that LFE channel content, played through the subs, is literally delayed 5ms, as stated. This is in contrast with the channels, where with bass management, the subs will also play redirected bass from channels.
The diagram show the acoustic timing reference step response of the LCR channels, and the LFE channel. I have labeled the peak of the subwoofer (playing redirected bass ) step response from LCR channel as '1', and the subwoofer (playing LFE content) step response peak from LFE channel as '2'. One can immediately see the ~ 5ms delay that is stated in the DIRAC release notes.
In the next diagram, it is the same acoustic timing reference measurement of the LCR and LFE. However, i have muted the LCR channel, leaving only the Subs active and playing the bass management redirected bass from LCR. These still peak at '1', and the LFE with the delay peaks at '2'.
What does this mean, and how does it explain why some HT content bass impact sounds clean and tight, while other HT bass sounds smeared and vague, less precise and less impact?
I think it has to do with the relative amount of bass information in the (LCR) channels, vs the LFE channel. This is what i mean, and i try to break it down to a few scenarios.
1) No significant bass in LCR channels, bass mainly mixed in LFE channel. In this scenario, DIRAC ART will perform marvelously, bringing all the clean decay, precise texture, transient impact that ART excels in. This is because there is not redirected bass from LCR, playing in the LFE, so there is only one bass transient peak, at '2' during playback.
2) Significant bass content in LCR channels, complimenting bass mixed in LFE channel. For eg, in 13 hrs First Wave scene, the gunshot impacts. There is significant bass transient peak from gunshots in LCR channel, in addition to LFE channel bass transient peak.
In this scenario, the 5ms LFE delay bug wreaks havoc in the bass playback, for both HT and multichannel concerts, especially gunshots and kick drums.
One common example is Roy Orbison's Blue Bayou from Black and White Night. The song starts with a very nice transient acoustic bass + kick drum impact, that is very noticeable smeared and less precise on ART.
Another common track is Green Day's Boulevard of Broken Dreams concert track, another bass kick drum monster test track. With DIRAC ART, the bass kick drum is a pale shadow of what it could be, what it should be.
The reason this happens, is the bass impulse peak content from LCR, being redirected and played by subs, is peaking at '1', and then at the same time, the same complimentary bass impulse peak from LFE channel, played by the same subs, is peaking at '2', a good 5ms later. The result is the transient impact peak is smeared across 5ms.
Another way to think about this, with multiple subs. What happens when you intentionally delay half the subs 5ms from the other half? There will likely also be associated cancellations between the first and 2nd peaks.
3) Significant bass content in LCR channels, little / no bass content in LFE. This is common for stereo 2.0 tracks, or multichannel 5.0 or 7.0 concert tracks, often classical concerts are mixed / mastered these way. With these content, ART again shines with bass reproduction. The subs (redirected bass) will peak at '1', there is no LFE channel bass to peak at '2' to cause smearing or cancellations.
I hope this post raises awareness and understanding of this issue and DIRAC can implement the fix very soon in the next release.
I truly believe ART brings the next level of bass performance in room, and already enjoy the incredible results with stereo content. I hope to enjoy similar with all my HT and concert content as well.
Thanks for reading.
Gavin
