Ignoring the peaks and any lines other than the dashed (dotted) vertical ones that signify the start of the signal to Dirac, the first dashed line is the LFE group and the second is all your other groups. If you place your cursor on the dashed line it will give you the ms and then place it on the other one, I think I'm seeing the difference is 4ms.
@mmares056 shows 2ms, and my current one shows the lines right on top of each other (zoomed shows the .2ms difference)
My current (see the 2 dashed lines on the bottom chart side by side compared to yours compared to mmares)
Zoomed same image (scroll wheel on the mouse) and you see the scale at the bottom is way zoomed as well (sub dashed line sits on the 99.4ms mark, it's baby blue and hard to see)
So for this piece which I am assuming is what Dirac is using for total system timing mine, mmares, and yours do not look similar because the subs are firing early for him and even earlier for you. My subs are .2ms later, but my last measurement with different gear they were 4ms early just like yours. After taking that wireless kit off and doing a new set of measurements my dotted lines align. I was assuming the wireless kit was causing my issue but recently more folks (you included) have shown the same discrepancy and with wired subs so I'm rethinking my previous conclusion and wondering what else could have improved the timing if it wasn't that?.
