And distance based time correction for multiple subs too?Correct. You do not set a crossover. ART takes care of it.
Yes, phase and timing.And distance based time correction for multiple subs too?
Is there no advantage to segregating bass and tweeter frequencies into separate channels? This separation would enhance the control for Dirac ART. Towers EQ is less controlable than bookshelf + sub in different channels.The issue at hand does not extend beyond SPL. At least the issue I raised. I can sense AI in your posts, which could be used for the purposes of translation if English is a challenge - but then the posts should make some sense and make the point. Your point is no point at all.
Now what does tweeter has to do with ART? And why would towers be less controllable? And what are "separate channels"?Is there no advantage to segregating bass and tweeter frequencies into separate channels? This separation would enhance the control for Dirac ART. Towers EQ is less controlable than bookshelf + sub in different channels.
As long as your AVR supports enough subs, some folks need something to combine some of their similar subs to present as one sub to ART. I’ve seen more than a few posts from Denon/Marantz folks with 4 subs and those butt shaker things trying to figure it out.Does ART negate the need for sub management with something like a MiniDSP?
The enhanced clarity was very obvious to me.Does Dirac Art really improve decay times by a noticeable amount, so that's audibly obvious? Is it night and day or more of a "might be noticeable depending on the situation"? I would hate to spend all the money on an AVR that supports this, buy the license and still have a "did it really improve the sound or was I imagining it?" type improvement.
I've said this before - but it bears repeating - you need 2 or more BASS CAPABLE SPEAKERS for best results (and ideally 3 or 4) - full range capable main speakers count! - hence you can get excellent results with 4 x full range speakers and NO subs... (FL, FR, SL, SR)If you look at the REW graphs submitted throughout this thread the answer is resoundingly yes as long as you have 2 or more subwoofers. Ideally 3 or 4 subwoofers. Dirac ART in most rooms shortens decay especially (40-120hz) and decreases seat-to-seat variation. Result is very smooth sounding even bass.
In lifestyle / room setup terms, an easier alternative to finding space for subs, is often to get full range mains and surrounds.I'm thinking of adding a second sub as this should already improve the bass in the room when dialed in. But investing in a third might be difficult. Would subs over 2 need to still be identical or would buying a cheaper, smaller subwoofer still work?
And if I can only use two subs, would you say it's probably not worth getting Dirac Art?
I'm just thinking of the investment in terms of financial commitment and space. My room isn't particularly large and it's open to a kitchen.
Dirac ART only works below 150Hz...Is there no advantage to segregating bass and tweeter frequencies into separate channels? This separation would enhance the control for Dirac ART. Towers EQ is less controlable than bookshelf + sub in different channels.
There is an alternative - use old tech, most subs still have the facility on them to integrate them with a speaker to make a full range speaker (built in crossovers, or adjustments to facilitate additive operation, with phase/level adjustments) - set them up that way - then let ART do its magic.As long as your AVR supports enough subs, some folks need something to combine some of their similar subs to present as one sub to ART. I’ve seen more than a few posts from Denon/Marantz folks with 4 subs and those butt shaker things trying to figure it out.
You are right, tweeters are out of the “magic” of ART, but Dirac can affect the full range of frequencies from low frequencies (subwoofers) up to highs (tweeters).Now what does tweeter has to do with ART? And why would towers be less controllable? And what are "separate channels"?
It is all relative. Your "case studies" are just not detailed enough, although more subs will generally do a better job. I have 9 full range speakers and 4 subs and when they say too much is never enough, they are wrong. Too much is just too much.Trust me, you are not speaking to an IA.
let’s have two assumptions
Case study 1:
-assymetric room (one side open to be living the other side is a glass window to the garden)
-2 towers that you can’t separate from the front wall (50cm away)
-you head is perfectly located in between the towers but you have the back wall just behind you head (50cm away)
-1 sub located on one side of your sofa.
Case study 2:
-same room, same listening position
-instead of 2 towers you have 2 bookshelf speakers at the same spot of the towers
-now you have 3 subs that you can locate in the place you want.
Would you consider that case study 1 is as configurable for Dirac ART as case study 2? Even in the case you have to locate the subs below the bookshelf speakers you would have more control over the bass, because you are comparing a 2.1 with a 2.3 layout. You can get the same amount of bass but less controlled.
Obviously you can have 4 towers, and 4 subs and there you solve the whole issue, but my point is simplier: is better to have more independent channels within Dirac to have more control of the room modes.
I have not used ART but you can see from spectrograms that it is consistently reducing spectral decay in 40-150hz region and reducing variation in peak energy time trace (peak level at any given frequency). It is absolutely working. It is using low frequencies from any speaker/subwoofer in system that is capable to do this.As someone that has used ART since it was in beta on the Storm, and believe it works wonders in a variety of setups and spaces... how certain do we know what it is doing?
A similar discussion was on AVS as well but I thought it was interesting enough to see what users think/know here?
Is it using active cancellation, like in headphones?
Is it using other speakers to contribute to the target curve?
Their early documentation seemed to talk quite a lot about active cancellation. It seems many of their later videos in particular don't.
This isn't really a question of if ART works, but do we know how it works and if it is using Active Cancellation or not? Is this possible to measure and has anyone done that which might prove one way or the other if it is using active cancellation?
I have used a semi-functioning DBA before ART. So yes, the cancelation principle. Based on that experience, I can say with 100% certainty that ART is doing cancellations - and in very effective way. My prior DBA and all the effort that went into it - a silly joke compared to what ART does.As someone that has used ART since it was in beta on the Storm, and believe it works wonders in a variety of setups and spaces... how certain do we know what it is doing?
I guess if you go loud enough, the lawnmower will not be a problem at all. But absolutely correct in stating the principle.Active cancellation implies a device (like headphones) is actively trying to cancel problematic noises. If you are using ART and your neighbour is using their petrol lawnmower, you will still hear their lawnmower. So ART isn't "active" in that sense.
ART does cancel "sound" in the room - you can see this on the waterfall charts - but the sound it "cancels" is sounds that have been produced by your audio system. This means it doesn't just cause your speakers to constantly output "negative sound", and instead just "outputs some extra sound" (includes extra sound in the signal) that will cancel out the decay (the ongoing sound reflections in your room).
So I guess you could call it "reactive cancellation", because it knows that your speakers will cause a certain in-room response, and that you want a different response, and thus it does what it can to fix the response (which implies cancellation of room decay).
