What exactly do you mean by “increased timing precision”? Are you referring to a higher sample rate? The smaller capsule of the UMIK-1 is actually preferable because it's more omnidirectional.Could you please specify the microphone you are using? While the above 500Hz correction using my previous microphone (Umik1) was not to my liking, the Umik2 offers increased timing precision that allows for a full range correction
The UMIK-1 depends on the external USB host clock, whereas the UMIK-2 uses an internal clock. So I’m not sure what Miniyouuuu means by “increased timing precision” in this context.Dirac ART does not really benefit from UMIK 2 the way REW workflows do. That is why Dirac still recommends UMIK 1. The main advantage of UMIK 2 is better timing and phase consistency, which matters more for manual alignment work like sub integration in REW.
No, this is not true for my Marantz Cinema 30, so it is not true in general. What processor are you referring to?I’m pretty sure what I wrote was incorrect, but I also don’t see anything written by Dirac stating that ART will disregard crossover settings. From what I’ve gathered now, I believe f support only limits how a speaker supports itself or other speakers. F support does not limit the bandwidth of the signal that is intended for that particular speaker. But the crossover setting in the processor does limit this signal’s bandwidth and Dirac sits on top on this.
It can be a bit of a handfull to understand how it worksI’m pretty sure what I wrote was incorrect, but I also don’t see anything written by Dirac stating that ART will disregard crossover settings. From what I’ve gathered now, I believe f support only limits how a speaker supports itself or other speakers. F support does not limit the bandwidth of the signal that is intended for that particular speaker. But the crossover setting in the processor does limit this signal’s bandwidth and Dirac sits on top on this.
Dirac locks down a lot of stuff and ignores others in Denon/Marantz products. The crossover and a lot of other settings are more for Audyssey than it is for Dirac (again, for D&M products). I'd be surprised if it's any different for Hyperion products.I’m pretty sure what I wrote was incorrect, but I also don’t see anything written by Dirac stating that ART will disregard crossover settings. From what I’ve gathered now, I believe f support only limits how a speaker supports itself or other speakers. F support does not limit the bandwidth of the signal that is intended for that particular speaker. But the crossover setting in the processor does limit this signal’s bandwidth and Dirac sits on top on this.
Interesting! How are these speakers and subs grouped into support groups? And how did you measure the supporting speakers individually?Measurements on how support works - left ch
LCR 30-150hz and -18dB
Subs 20-150hz and -24dB
Oh well, I must admit that I dearly care only for one seat in my HTThe risk of full range correction in general is you start chasing a seat-specific variation.
. My kids and wife not interested much in my toys...Did you measure the left channel and then measure the left again but with all the other channels disconnected so this represents what ART is doing?Measurements on how support works - left ch
*edit*
My LCR without Art and full range goes down to 25hz
Although I honestly forgot the settings before ART measurements as it was couple of months ago, my understanding was always that Dirac would do full range sweep for all channels to determine in-room response of the speakers. This is Dirac's own protection as well since they definitely don't want to be blowing up the speakers.Dirac locks down a lot of stuff and ignores others in Denon/Marantz products. The crossover and a lot of other settings are more for Audyssey than it is for Dirac (again, for D&M products). I'd be surprised if it's any different for Hyperion products.
AI gave me a bogus answer the other day and assumed the wrong units of measure. This can lead to engineering disasters like the '99 Mars Orbiter loss or the '04 Tokyo Disneyland Space Mountain derailment! I don't think you can go wrong with "trust, but verify" as a life-long adage!
Would you be willing to share this mdat? I'm interested in seeing how other aspects are affected by ART. If you're feeling especially generous, I'd also love to see the left channel with no Dirac processing for comparison.Measurements on how support works - left ch
*edit*
Don't think it is so unclear. Just completely different principle than traditional crossovers. What is happening is best shown in Dirac graph after you calculate the filters. Below is the screenshot for my Front Left. It is supported by Wides, and Surround backs, and off course group of 4 subs. Range of support for beds is 50-150 and intensity 18. Subs are 20-150 and intensity 24.I must say it’s clear a mud as to how crossover settings in AVRs and processors are taken into when ART is active. I haven’t seen a clear statement by Dirac in any of their YouTube interviews, nor a clear instruction in a manual, Dirac or otherwise. The range of theories on this go from Dirac completely ignoring the settings to Dirac running on top of the processor bass management. Dirac setting these to automatically maximize the speakers as a system doesn’t necessarily mean it ignores the crossover settings. Regarding F support, best I can tell this only affects the bandwidth of the support anti signal not the original signal that is intended for a particular speaker in a multichannel set up. If Dirac is ignoring the crossover settings then why does it lock them? Please point me in the right direction if you know otherwise.
Kind of,Did you measure the left channel and then measure the left again but with all the other channels disconnected so this represents what ART is doing?
