Based on issues/lack of support from current Arcam Dirac users in the big Dirac AVS thread, I'd stay away from Arcam as far as I can!I saw new Arcam Radia AVR's with ART being announced. Expected delivery Q3 2026
4 subsHow many subs are used in the system ?
Thank you
No issues experienced with Windows 11 here...Well, no Windows in my house for years except the ones on the wall. Used it only for MultiEQ-X and suffered every time.
When you describe a driver producing a "clack" sound on low frequency content, then that seems to me like a driver is hitting its excursion limits. The subs you mention are ported, with the port tune at 19 Hz. The LCR are ported with a tune at 35 Hz. If a bass signal below the respective port tune frequencies is fed to the sub or the speaker then that might account for the sound you are hearing. This becomes more likely at higher signal levels.This noise is a distinct 'pop' or 'clack' occurring on low-frequency content (such as kick drums or bass lines) and is consistently reproducible on specific tracks. The issue disappears completely as soon as ART is disabled.
Always nice to see suche a beautiful systemIn my experience nothing wrong with 4 subs, in fact they really can go beyond ART if capable enough - the most demanding torture exercise involved additional +10dB gain on the subs to all that ART and AVP could provide (+5 master, +12 curve). Subs were just, let's say, humming along. More appropriate would be that they were tearing down the structure 5 floors up and down, but limiting volume to 130dB through their DSP.
Other speakers were not really breaking a sweat or needing a break at these levels. Even the Atmos are good to 50hz F3 response. This was for multiple hours as wanted to see how far and long I can go. Posting pictures just for new members that might not be able to use search function well.
As far as Focals, there is a serious review out there on Focal system with ART. Albeit there was RBH infrasonic sub as well. So looks like nothing wrong with Focal setup after all.
Focal 1000 Utopia IWLCR & IWSUB Speaker System Review
Focal's 1000 Utopia and Astral 16 deliver reference grade performance from an in-wall speaker. Check out our exclusive, in-depth, Focal 1000 Series Theater installation and a sneak peek at Dirac ART.www.audioholics.com
Also to consider, in a ported system Xmax is Very easy to reach 10-20hz above tuning frequency. (see random pic below)When you describe a driver producing a "clack" sound on low frequency content, then that seems to me like a driver is hitting its excursion limits. The subs you mention are ported, with the port tune at 19 Hz. The LCR are ported with a tune at 35 Hz. If a bass signal below the respective port tune frequencies is fed to the sub or the speaker then that might account for the sound you are hearing. This becomes more likely at higher signal levels.
Note that if the subs and LCR speakers are providing support to other speakers using ART then the bass signal will be more powerful and perhaps significantly more powerful than just the original sound content, depending on ART configuration.
If the subs have the ART "infrasonic" option ticked then more bass may be present below 20 Hz, but it isn't being managed by Dirac, so might be presenting too much bass below 19 Hz. It seems more likely that there may be too much bass signal below the LCR port tune of 35 Hz and the mechanical sounds are coming from one or more speakers. This might occur if the LCR speakers are being set in ART to support the subs or other speakers at frequencies below 35 Hz.
Just some food for thought and ideas to investigate
Damn I missed that 35Hz tuning of the LCRWhen you describe a driver producing a "clack" sound on low frequency content, then that seems to me like a driver is hitting its excursion limits. The subs you mention are ported, with the port tune at 19 Hz. The LCR are ported with a tune at 35 Hz. If a bass signal below the respective port tune frequencies is fed to the sub or the speaker then that might account for the sound you are hearing. This becomes more likely at higher signal levels.
I Many cases it is this that defines max db - not power input.
Thank you so much for taking the time to explain! I prepared a few questions for the calibrator who did DIRAC ART on the configuration in questionWhen you describe a driver producing a "clack" sound on low frequency content, then that seems to me like a driver is hitting its excursion limits. The subs you mention are ported, with the port tune at 19 Hz. The LCR are ported with a tune at 35 Hz. If a bass signal below the respective port tune frequencies is fed to the sub or the speaker then that might account for the sound you are hearing. This becomes more likely at higher signal levels.
Decidedly, you don't want to get to the bottom of things, or understandAs far as Focals, there is a serious review out there on Focal system with ART. Albeit there was RBH infrasonic sub as well. So looks like nothing wrong with Focal setup after all.
Sorry for not replying@gepgep, you never answered me but I found from one of your earlier posts. Since you have the Cinema 30, you should make sure it's fully updated as there were issues earlier w/WIDE speakers and Dirac.
Is it a 12" or 15"The JBL subwoofer driver I bought the other day broke, so I tried replacing it with a driver called the STW-350F.
As a result, the response around 20 Hz is much more solid than with the previous subwoofer driver, and I’m very satisfied.
There were a few mishaps along the way, such as the rear reinforcement brace interfering with the driver, but in the end, everything worked out well.
It’s a 15-inch driver! It’s an excellent performer!Is it a 12" or 15"
Martini shakerIt’s a 15-inch driver! It’s an excellent performer!
