Well, I
finally had time this weekend to finish up my system wiring in the new house and run a basic ART calibration on the HTP-1. I've done nothing yet except accept the ART default groupings and parameters so I could hear something, and I just did 9 measurements. I used a Neumann MA-1 microphone hooked up via an iRig Pre HD USB mic preamp. I anticipate doing a more full-blown measurement set, validations, and fine-grained tweaking over the next who-knows-how-long. But right now I just wanted to listen.
First impression is I am very impressed, honestly more than I thought I would be. For the last week or so we had been listening to a 3.0 setup with just the LCR. Because they're very good speakers with no apparent dynamic limits in this size space and they are fed stupid amounts of power, they were a very pleasant listen. But ART just transforms the upper bass. There's still a decent amount of tactility and punch, but room boom is just
gone. The room sounds much larger than it is, which is just roughly 14' x 17' x 9', with 117" listening distance to L and R speakers. I'm sure over time and after a cycle of validation I'll find things to tweak, but right now I'm just enjoying finally having a real immersive system up and running again for the first time since mid-August.
For reference, the system is in a multipurpose family room with a 7.1.4h hybrid Auro/Atmos speaker layout with 4 subs*.
LCR: JBL LSR708i, Crown DCI8|600n (single wire configuration)
Sides/Rears: JBL CBT100, Crown DCI4|600n
Front/Rear Heights: JBL LSR705i, Crown DCT8|600n (single wire configuration)
Subs: 4x ~85L closed boxes, mounted in the four corners of the front wall (floor and ceiling). Floor subs are, respectively, 2x Aurasound NS15-992-4A and JBL 2288H (successor driver to the 2269H used in,
inter alia, the Sub18). Height subs are each BMS 18n850. Amp and EQ for all subs is Crown DCI4|1250n.
*There's a 5th sub in the room, a
Tymphany LAT-700 driver in a closed box of about 28L integrated into the media cabinet, but it is not currently hooked up. I am curious if having a bass source that's asymmetrically placed and bandwidth/level limited will make things even better. But that's something for another time...
Front of room image (from "
aesthetic subs" thread):
One thing I do want to note: most consumer amplifiers are IMO inappropriate for most modern immersive systems. You really need to have level controls on each amp, because your height speakers are usually going to be both the least sensitive and the farthest away from the RSP. By dialing in the relative amp levels at Dirac's volume trim stage -
i.e., adjusting the trims on the amps in Audio Architect to change the actual relative levels rather than adjusting the level slides in Dirac - I was able to keep just a 3.7dB level delta in the post-calibration channels, and save plenty of headroom for Dirac.
(Not sure why LS and RS are 0.1 ms off, lol.)
