Active Room Treatment (ART) by Dirac
I’m running a miniDSP in front of the subwoofers, but since I no longer use the system with
Dirac turned off, I’ve stopped doing any kind of pre-tuning with PEQ.
It didn’t really make much sense anymore.
What I did keep, though, is using the miniDSP so I can boost the volume of all four subwoofers with a remote.
That means I can push the sub level even further beyond the maximum Denon volume.
I haven’t tried it yet, but boosting something like +10 dB sounds like it could get pretty wild.
On Storm, I think you can probably save presets more or less without limits.
Personally though, I really like the Quick Select feature on Denon/Marantz.
Love the presents as well and thanks for reminding me of those.
I posted somewhere my extreme test with +12dB Dirac curve, +5dB to reference and +12dB on subs via their DSP. Ran it for couple of hours for good measure and all ended up well. However, it was so loud that I could not even hear the rattling in the room. Sound pressure was also overwhelming and punishing. My neighbours floor up and down were out for holidays, but my family flat two floors up was shaking and rattling. Was more of equipment and ART settings test - not planning to repeat it or listen to those levels ever again.
Even with just low frequencies from the subwoofers, that level must have been physically exhausting.
Did you run it for several hours straight while watching a full movie?
In my case, during the daytime it probably wouldn’t bother the neighbors, so I’d like to try it as an experiment when I’m feeling well.
I recently tried turning the Denon volume all the way up, but I ran into the preamp limits of the Denon.
I wanted to increase only the subwoofer gain, but it’s a difficult setup.
Since it’s a knob-based volume control, once you turn it up, it’s hard to get it back to exactly the same position again.
Did not respond to your previous posts as unfortunately busy and ultimately did not know how to help.
I have 8000s in my second HT for fronts and surrounds and the way they kick bass is out of this world. Other things they don't do as well, but bass is their strength. They easily go to +5dB to reference, but then sound too harsh if curve not calibrated for that. Albeit that is in smaller room and no ART, but they are ran as full range in HT setup with Parasound amps and 6700H in pre-amp mode. These things actually move air that you can feel at MLP some 2 meters away.
This would lead me to conclusion that Timo already mentioned. Something might be clipping in the chain. Or the speaker is damaged and not functioning properly. If I recall correctly you do go back to the same clip to reproduce this. If this does not happen more widely, that clip might be mixed inappropriately so that what you hear is actually normal.
Reducing ART support might help, but ART is likely not the cause of this problem. I recently ran some extreme and time extended tests on my system with +5dB to reference volume and 50-150hz support range for all my bed speakers at 18dB, and all worked fine. I am sure 8000's could take the same torture as owned both sets of speakers for years - albeit 8000's would tear my ears in mid and high end if curve not built for these levels.
Below is response on front pair of 8000 per Audy - it’s very much in line with REW which I don’t unfortunately have any more.
Good advice, Oddball.
Yeah, it really doesn’t seem like ART is the cause.
That was a test so I was there perhaps first 15 minutes and running various clips to get comfort it will work and not break up things. Then in and out for the rest of the test. Was incredibly loud so could not manage to be in there for the whole time.
I also can't do more than +5dB to reference as Dirac takes rest of it for headroom. Did not try on other gear but probably the same. Pro gear might have a bit more headroom. But then +5dB to reference is way beyond loud.
ETA: For a <= 16 channel count the HTP-1 seems like another great option. As long as you don't require the HDMI 2.1 enhancements which are really only relevant for video games and not media consumption it has a lot of features the D&M lack. More filters, tone controls, loudness, etc. @TimoJ can better explain all the nice features it brings to the table.
Do D+M give one the ability to independently validate each channel, i.e. steer a test tone from REW et al. to any channel?
Do D+M give one the ability to independently validate each channel, i.e. steer a test tone from REW et al. to any channel?It will work exactly as it works on other room correction systems so I guess the answer is yes.
It will work well with REW as any other room corrections system would.
However, each channel will be supported by other channels according to your designation, so what you will hear in the REW sweep will be the sum of that.
With ART it is about collaboration and summation of the group of supporting speakers for each channel.
That’s not the question though. What I'm asking is if the AVR/P itself has a function to steer a test tone to any channel, so you can validate it with an external measurement software. For example, from HTP-1:
IIRC you can't access height channels directly over HDMI otherwise. OTOH, if the newer version of HDMI allows such access then I guess the question is moot.
While I would be like to be helpful don't really understand how HTP-1 works or what options it has or how they work with ART.
As far as D&M, I did post what you can get out of it.
Always interesting to learn more so if you can explain what HTP-1 does would be much appreciated.
BTW - I hit like button when interacting with people out of courtesy. Does not necessarily mean I like the post or where they are coming from.
Think about it like this: you want to measure the post-ART results for the front left height channel. How do you inject the test signal into that channel on a D+M AVR/P.
OTOH, HTP-1 may not work like I think either. I’ve sought confirmation.
The way to do it is limitation on REW not D&M. You would have to re-wire your setup so that your heights appear as your surrounds to REW.
Nor really sure it warrants all the fuzz about it but get the point. Since we all (well most of us) posted our graphs in this thread, perhaps you could do as well. No better way to get credibility than put your graphs where your mouth is.
Point taken that one can rewire the system to achieve the same end goal, but the rest of your post is completely irrelevant to the workflow question I posed.
How do you rewire your system and still keep proper ART correction for the channels?
With the HTP-1 (and StormAudio) you can map L/R channels to any channel and then use REW to send signal to L/R. I usually use right front as acoustic reference. So here I can measure right top middle with REW and ART active:
I have made couple of points, none of them irrelevant IMO.
I think that your post was ignorant, and partially rude, as one knowing how REW works could have figured it out easily without the need to spend valuable environmental resources to useless question. But guess that just shows where you rate on the scale of things to know.
You wanna dial it back a bit? No need to be so hostile.
I agree that I was ignorant as to this particular functional limitation of D+M boxes compared to more advanced hardware (that may be considerably less expensive in some cases). After all, that’s why I asked the question. Thanks for answering after my clarification. For people who want to validate all channels, this is useful information.
I will admit that I am partially wrong based on Timo's post. That is just how ART works with D&M and I guess did not have enough time to adjust to some limitations that it poses. The workaround to get good reading on the Atmos for REW would need to be quite extensive, starting with measuring them as surrounds with the calibration.
Perhaps part of my ignorance to the whole issue is that I never measured Atmos in REW and don't really plan in foreseeable future as their impact does not appear to be very significant. They really work quite well, courtesy of ART and when called for, they perform well. Always like to quote The Masters of the Air and the air battles.
It would be another plus if HTP-1 can do Atmos speakers check with REW the easy way, but can you guys confirm it actually works with REW? I do have mapping issues with REW but that is between surrounds and back surrounds that I really don't care about.
Yes, it works.
For Denon/Marantz: there are REW sweeps encoded with Dolby Atmos, so you could use those to measure top speakers with REW.
Download from this videos description text's Google drive link:
Thought I'd finally throw my hat in the Dirac ART ring. I've been playing with various EVO 1 flavors to this point and think I've taken that as far as I can go (or want to).
So I've done one set of measurements, 9 point around the MLP. All using my A1h of course. Setup is 9.4.6.
Some observations.
During level setting the UMIK1 would occasionally go quiet (noise floor goes from -50dB to -66dB), but would come back. No idea why.
I never lost the mic during actual measurements however, so that's good.
Also finally dawned on me that level setting is not to set equal volume for all the speakers, it's only to get them in the ball park. This discovery after trying to get them all within 0.5dB of each other with the less than accurate sliders. Live and learn. I set the subs several dB higher, as recommended. They all ended up with negative trim, so all good.
Then did the 9 point measurements, uneventfull. Except my discovery that one of my Studio 2s seems to have a bad tweeter. It makes a clack sound as the sweep transitions up from the midrange. Never heard that with the Audyssey chirps. Doesn't affect the frequency response, however, it's the same as my good one. I have a request in to Revel about a replacement (ouch!).
On to filter gen. The default ended up using 89 of 92 filters. So this is my first question. I've variously seen 'max filters' reported as 94, 96 or 98. Mine shows 92. Anyone know any reason for this variability? Also my 'filters used' is always displayed. So I suspect it only is shown as you get close to the limit.
All the speakers were grouped by pairs. All support levels were set at -18dB. All support frequencies were 50-150, except my overheads, which got 75-150 (these are M55xc), seems low but they are only supporting each other, so probably fine. Subs support everybody. Surrounds only support Center. Center supports Fronts, surprisingly, but it's a C426be (flat to about 40Hz in room), so probably not surprising.
Wides are supported only be subs, surrounds are supported by surround backs, surround backs are supported by wides. Heights support only their group mates.
So it all seems to make sense, surprise is the fronts don't support anybody and the center supports the fronts. I tried using some remaining filters to have fronts provide support to LFE, which works, but doubt it would add much.
Now on to the listening, which I have not yet done.
So 'all' supporting 'all' is not the case for me (too many channels I suppose) and the fronts only have to take care of each other. And I'm filter maxed out. This is actually a bit of a relief, since it limits any tweaking from here out. I've gotten a little tired of playing with unlimited variables. Maybe play with support levels and raise a few FS lows.
I did three versions with different target curves, two full range correction and one limited to 500Hz. Will report back when I have some opinions to share.
So you removed your atmos from supporting any other speakers but assuming the other speakers are supporting your atmos? And you are supporting LFE with your other speakers too?
Yes and yes - I removed my height speakers from supporting any other speakers, but they are indeed being supported by the base layer speakers and the subs. - End result (depending on configuration) was between 53 and 63 filters - and exemplary objective results
Think you got some good advice already. Just to note two additional benefits from Storm. It allows PEQ before ART which could be used to cut some peaks in frequency response to present a flatter curve to Dirac. Difficult to say what kind of benefit this provides as it will be very much room/system dependent. Similar thing could be done for subs if they have their own DSP.
Also, Storm has tone controls after Dirac, so one can adjust in addition to what was addressed in presets. Not sure, but likely Storm would have more presets than 6 you can use on D&M.
I agree that higher filter count for Storm (or HTP-1) faces a steep cliff in terms of potential additional benefit. I find 94 filters more than enough for 9.4.4 system, but can't deny that more is usually better. We also don't know if D&M implementation was limited by the DSP or with approach that simpler is better.
It could potentially happen that we see more filters on D&M in the future, and hopefully we will see tone control for Dirac as they already have it for Audy.
I would not go Storm as really happy with Marantz AV10, but there is no question that Storm does provide some additional flexibility.
It would be surprising if subsequent generations of DSP didn't have more processing power!
Manufacturers will have the choice of delivery same processor power at lower cost, or higher processor power at the same cost....
I expect currently high end DSP power levels will trickle down... with that process now limited not by hardware capabilities, but by software licencing.
And of course mid and high end DSP's will get more powerful, and will get the latest and greatest software.
I don’t know exactly why the Klipsch 8000 is breaking up when used with ART, but there are a few possible countermeasures.
You can raise the lower limit of the support range, reduce the assignment by setting the support level to something like -6 dB, or stop using it to support LFE.
I also don’t know whether switching to a higher-output speaker would improve the situation.
For now, please try adjusting the settings so that no distortion issues appear in REW.
When within the speakers capabilities, I am finding that the ART supported speakers are showing lower measured THD at the standard 75db SPL (@ MLP) than when they are run "direct" (without ART).
The Distortion / SPL / Support system environment is highly complex, some of ART's capabilities seem limited by speaker distortion, while at the same time, judicious use of ART seems to reduce THD at moderate SPL, as the SPL rises and the speaker level distortion rises, I expect that some sort of negative / harmful interaction may potentially complicate things.
I think we are still working out what is happening, and what measurements will be of most utility for understanding that environment... Our current toolset, originates from "simple" stereo environments, setups and toolsets.... (later extended to multichannel, but without major changes).
ART brings a layer of complexity to this picture that the traditional tools/graphs/measurements struggle with.
I find the waterfall chart to be particularly informative - it basically didn't exist 20 years ago (other than perhaps in academia, but you certainly didn't see it in audio reviews!) - now we need to find the measurements that will be relevant to this new toolset, and then we need to find useful ways of displaying those measurements so the output is useful...
At a high level - we have a multidimensional problem involving THD, time/decay, frequency, and SPL (at a minimum) and we need to combine the variables into some form of useable output that we can then leverage to optimise our setups....
Interesting Times.
