Hmm I was running 3.13.16... must update...I'm running Dirac Live 3.14.0 on a windows PC.
Just downloaded "dirac-latest" and installed it, which puts me on 3.13.16....I'm running Dirac Live 3.14.0 on a windows PC.
OK now running 3.14 - loaded my ART project, went to filter design - and the filter # is right where I expected it to be....I'm running Dirac Live 3.14.0 on a windows PC.
I don't know, but ChatGPT seems to know, and 240 is the number:Do you know if there is any way to find out how many "cross terms" you are using for your 7.3.6 setup in an all to all configuration?
Thank you for verifying. I will contact Dirac Support.OK now running 3.14 - loaded my ART project, went to filter design - and the filter # is right where I expected it to be....
Maybe needs a message to Dirac support?
Not going to defend D&M for limited filter implementation - more is definitively better. From practical perspective though, measurements on D&M gear look quite good.ART will never require more than this. With fewer than this, ART is not operating at full capacity.
How do I check that?@TimoJ - do your subs fire a bit ahead of the mains as that happens with some D&M systems?
There are couple of ways in REW. I usually use this diagram as can see other things as well.
Dotted line on the bottom shows that most of the spectrum is delayed a bit compared to subs. Disregard 20-30hz bump at the beginning of sub response. Not good but it is what it is. Looks like after ART handover to Dirac Live, it gets a bit bumpy.
It doesn't reflect what happened in my setup...I don't know, but ChatGPT seems to know, and 240 is the number:
When the number of active channels is 16, the calculation is straightforward.
Dirac ART uses the following principle:
cross terms = N × (N − 1)
where N is the number of active channels.
Calculation
- N = 16
- 16 × 15 = 240 cross terms
Interpretation
- 240 is the theoretical and practically required number for all channels to be able to support all other channels in the ART algorithm.
- If Dirac ART reports a lower number, it means:
- a hardware or DSP limitation, or
- optimization performed by Dirac where not all cross terms are enabled.
Is this for your front left? (Edited) Never mind. I saw you edited your post.There are couple of ways in REW. I usually use this diagram as can see other things as well.
I don't know Dirac's specific terminology, like what they mean by cross terms or even by filter honestly, but just in terms of signal processing if we define a "filter" as the tool that modifies a given channel's signal to be played out of a single speaker a fully supported system of N channels would require N*N filters. N filters for the speakers that are that channel themselves (traditional room correction), and N-1 filters for each additional speaker being used as a support. So a 5.1.4 system would require 100 filters to be fully supported.It doesn't reflect what happened in my setup...
Initially configured as 5.1.4 - which using your formula should provide 10 active channels and 90 cross terms - but the default (everything supports everything else) configuration reported 98 in use
Dropping off the heights, making it 6 or 7 channels (depending on # of subs) - the calculation returns 30 or 42 cross terms - but actual implementation had over 50.
So yeah, that ain't it... more information needed!
I checked the Dirac's internal value with those setups and it was 90, 30 and 42. So the formula seems to be correct. But something else is added on top of that when it's displayed.It doesn't reflect what happened in my setup...
5.2.4 with subs in a single group (as per default - splitting them into seperate groups used more filters!) - with the heights being supported but not supporting anything... 63 /98I checked the Dirac's internal value with those setups and it was 90, 30 and 42. So the formula seems to be correct. But something else is added on top of that when it's displayed.
What exact number did you get with 5.1.0 and 5.2.0 setups? Knowing that would maybe allow to see if the added number has some logic.
The number I can check is the max number, it won't change when support or groups are changed.5.2.4 with subs in a single group (as per default - splitting them into seperate groups used more filters!) - with the heights being supported but not supporting anything... 63 /98
Note that this is not a true 5.2.0 config, as the heights are present and being supported by subs and base layer - I merely removed them from supporting all other groups (which dropped it from 98/98 down to 63/98... and provided far far better results!)
Can't open my 5.1.4 projects... I would need to reconfigure the AVR to 5.1.4 before Dirac will load the project! - from memory it was 53 (I think)
That may have to wait a while....The number I can check is the max number, it won't change when support or groups are changed.
So, in order to (maybe) figure this out, you would need to check what number a real 5.2.0 or 5.1.0 setup shows with full support enabled.
drive.google.com
As a starting point it might be worth while measuring your subs distortion at the reference level...I've posted this in the main Dirac live forum but no one can explain what I'm seeing
I'm running 9.4.4 in a dedicated room with acoustic treatment including bass traps in the rear corners
The subs are in the corners.
The longitudinal room mode is around 21.4Hz
When I measure the results with REW, both DLBC and ART show higher distortion and worse decay than no Dirac around the region of the room mode.
I attach the .mdat file for those interested
The most telling result looks to me to be taking the Decay measurement at 200ms
No EQ has a decay of 25db aT 21.4Hz Distortion 0.22%
ART with flat curve (0db rise) gives only 5db Distortion 3.23%
ART with 10db Harman curve gives only 2db Distortion 2.26%
Results are slightly better with DLBC but still much worse than no Dirac
I've run multiple calibrations across MLP, front row, both rows and the basic principle doesn't change.
I thought maybe Dirac filters were the cause but 10Db Harman maxes out filters at 10db andFlat uses no gain filters at all and they both have poor decay/increased distortion
If any one has any ideas?
CAL 36 TESTS.mdat
drive.google.com
