Not sure I am following. If your current preset 1 is an Audyssey measurement than preset 1 is currently Audyssey with whatever set up you loaded and saved in preset 1. With Dirac you are using preset 2 IIRC, Dirac allows 3 slots within that preset for different "tunes". So with Audyssey you get one tune per preset but with Dirac you get 3 tunes per preset of availability. With Dirac I have not measured my overall set up more than once (yet) but my understanding is you can load any project you have saved into any of the 3 slots. So you could have a tight measurement of 9 points in one slot, a tight measurement of 16 points in another, and a wide seat measurement in slot 3 if desired. Or you could have 3 variations of support settings or whatever based on the same measurement. Your term of base system measurement is where I get lost as I don't understand if you mean a new Audyssey measurement, a new Dirac measurement, or base settings (defaults) applied to a current Audyssey or Dirac measurement? Hope this helped?
